603,418 active members*
3,282 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Perfect Curves from Visual Mill
Results 1 to 3 of 3
    We have recently purchased Visual Mill Expert which runs inside our Geomagic Design drawing package. At present when I produce a 3-axis horizontal finishing tool path the finished article is coming out as a series of small facets/flats. Can someone please point me in the right direction to fix this? Or, Is it possible to machine perfect radiuses with a tool path created by visual mill in geomagic?
    I would appreciate any comments. Thank you.
    Jan 2004
    3154
    Re: Perfect Curves from Visual Mill
    You need to use the fit curve option. In my version it is in the advanced tab of the MOP.
    Alternatively you can use toolpath fitting in the toolpath editor.
    I also suggest you join the MecSoft forum to get the best answers to your questions
    www.integratedmechanical.ca
    Apr 2004
    5948
    If you're machining a mesh file, you might check how large your polygons are. If the surface is coarsely tessellated, then those facets are really there, and fitting the toolpath more closely to them will just make them stand out more. The solution in that case would be to remesh to a finer tessellation, using more triangles to make the facets smaller, until you can't see them and then rewriting the toolpaths.
    Andrew Werby
    Website
  1. Visual Mill 6.0
    By ibrich in forum Visual Mill
    Last Post: 08-14-2014, 09:48 PM
  2. Visual Mill 6
    By Prboz in forum Visual Mill
    Last Post: 07-07-2014, 06:49 PM
  3. Replies: 1
    Last Post: 11-08-2011, 05:30 PM
  4. Visual mill
    By merritt boyd in forum Mach Software (ArtSoft software)
    Last Post: 06-30-2007, 11:24 PM
  5. Bob CAD or Visual Mill
    By nandomax in forum Uncategorised CAM Discussion
    Last Post: 05-25-2007, 02:55 PM
