587,997 active members*
3,240 visitors online*
Results 1 to 3 of 3
    Sep 2014
    3
    Ball Screw Bearing support
    My company is having a Ball Screw repair/Replace done for our Takahashi TNC-L1 microstar. I was wondering if the Ball screw support bearings HAVE to be precision bearings (BS 20/47 7P62UF) or would it be fine to just match the bore diameter etc.. to the existing housing.
    Re: Ball Screw Bearing support
    the locating bearing at the drive side?
    This bearing needs to be precise and stiff - or the machine itself will not be precise and stiff.
    So yes - it needs to be a precision bearing even though they often cost a little fortune.
    Christian
    My CAM Software and CNC Controller: www.estlcam.com
    Dec 2009
    972
    the bearings must be from P4 or P5 class of precision and the ballscrew must be pretension after replacing the bearings for a good accuracy during machining.
  1. Question (lead screw bearing support)
    By wmpinion in forum DIY CNC Router Table Machines
    Last Post: 02-27-2013, 12:47 AM
  2. Ball screw fixed support with 0.46mm backlash?
    By timber_MG in forum Linear and Rotary Motion
    Last Post: 06-09-2009, 11:05 AM
  3. Bmc ball screw support bearings
    By JWC in forum HURCO
    Last Post: 09-27-2008, 03:56 PM
  4. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  5. Loose ball screw support
    By cbass in forum Uncategorised MetalWorking Machines
    Last Post: 08-07-2006, 02:01 AM
