588,556 active members*
4,878 visitors online*
Results 1 to 2 of 2
    Aug 2014
    111
    Need help starting point and ending point wont contact
    Hello. I have little bit modified china laser with ketai gold board. I use my machine everyday and its works fine.
    Now I have small problem. If I make cutting works like circle, starting point and ending point wont contact. There very small difference. Yesterday I tighten my laserhead belt littlebit . Today I saw this problem. Difference is very very small. Any help? I clean mirrors and lens Also check aligment. They are fine. If I make jewelry so almost everytime it cuts fine but I see starting / ending point on my cutting works..
    Re: Need help starting point and ending point wont contact
    the problem should be in the belt, your x and y tighten is not same
    so pls cut a square 10*10cm ,and see length and height
    tina from g.weike laser
    EMAIL: [email protected] SKYPE: lysunshine521
  1. I need a starting point
    By G02 in forum DIY CNC Router Table Machines
    Last Post: 03-13-2012, 12:05 AM
  2. VM5 Toolpath starting point
    By Prboz in forum Visual Mill
    Last Post: 11-06-2008, 11:07 PM
  3. here is starting point for the new guys
    By spider in forum Casting Metals
    Last Post: 09-10-2006, 06:10 PM
  4. mold 1st contact point marks
    By nbedard in forum Vacuum forming, Thermoforming etc
    Last Post: 11-15-2005, 06:07 AM
