588,202 active members*
4,805 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > way to tell if your machine is set up for "DOG LEGGING"?
Results 1 to 3 of 3
    Jan 2015
    17
    have had a few collisions with some 3d programs lately, tool comes across and clips the machined area
    plotting points shows theres noway It should touch but they sure do
    1 suggestion is to checkand find out whether or not the machine is dog legging
    it seems as though in rapid mode the machine is traveling faster in the x axis than y
    how can I verify this setting on our vf6
    Mar 2010
    1852
    Re: way to tell if your machine is set up for "DOG LEGGING"?
    Haas does have dogleg rapids. You need to set your CAD post to avoid interference or clear the tool before the move.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Feb 2009
    6028
    There is a setting on the newer (5 years) or so for dog leg or not. I had to set one of ours up to dog leg if the 4th axis was attached, since they had a software bug.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
  4. First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000
    By buschhoff in forum Want To Buy...Need help!
    Last Post: 03-21-2010, 12:37 AM
  5. Questions on building small (18" x 24" x 3") machine
    By bikedude880 in forum DIY CNC Router Table Machines
    Last Post: 08-01-2006, 03:04 AM
