588,707 active members*
13,101 visitors online*
Results 1 to 3 of 3
    Sep 2006
    39
    Pluggable terminal block?
    Any one know the proper name and source of this type of plug. I need to find a 7 terminal one for my BobCAD 5050 router. It has BobCAD's name on the control box but would suspect Aniheim Automation built it. The top socket is for the limit switch s. The others in the picture are the motors, but should give you an idea of what I am looking for.
    Dec 2003
    24222
    Practically all the terminal manufacturers make them, Weidmuller, Entrelec, Phoenix contact, Tyco-Amp. They are ordered by pin spacing .2", 6mm, etc.
    Al.
    Albert E.
    Sep 2006
    39
    That helps. I do see a 5mm on one side of the plug and what I think is P60 on the other. I think I figured out the 5mm but what is the P60?
    I found this one at http://www.riaconnect.com/_assets/catalog/tb_93.pdf
