588,201 active members*
4,882 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > How to reassign a part to a different layer
    Jun 2009
    113
    I've been using rhino for quite some time but sometimes I still can not figure it out. If I draw a part in a layer and decide to to reassign to a different layer how do I do it?. If I go to the layer button and bring up the layer menu I still can not get it to move to a different layer. I know it can be done but I'm not getting it. Any help out there.
    Steve
    Re: How to reassign a part to a different layer
    Quote Originally Posted by Barefootboy4 View Post
    Steve
    This process does not work?
    1) Select all of the objects you wish to Change Layers.
    2) In the Layers Tab; position your mouse over the layer you wish to move to and Right-Click.
    3) A menu pops-up; select 'Change Object Layer'
    More tools in the pop-up menu too;
    Apr 2003
    1357
    Or use the ChangeLayer command.
    Or use the Properties pane.
    Jun 2014
    1780
    I select the object for the new layer and use the "copytolayer" command, type it in the command line, then select the layer or click the new layer box.
    mike sr
  1. 05 How to order by layer
    By thunderlaser in forum Laser Control Software
    Last Post: 08-23-2013, 09:40 AM
  2. Layer after layer of color
    By cncadmin in forum EnRoute
    Last Post: 09-27-2011, 07:40 PM
  3. What to use as a sacrificial layer
    By xchipx in forum Composites, Exotic Metals etc
    Last Post: 03-12-2009, 12:23 PM
  4. Paths got into one layer
    By Jdavis733 in forum EdgeCam
    Last Post: 08-29-2008, 04:25 PM
