587,827 active members*
2,949 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Tsugami - main/back spindle rotation phase synchronisation control
Results 1 to 3 of 3
    Sep 2007
    12
    Just got the new Tsugami HS265-5AX and I'm looking for some information or documentation for setting up the back spindle.
    I'm working with a special collet which has an inside form (it's not round). I would like to synchronise the main and back spindle rotation/phase. My problem is just how to handle the two parameters 4135 and 4034?
    I have to correct a mistake from my back spindle which is about 37 degrees off with the main spindle?
    After that how can I check if my correction is fine with the MDI mode?
    The explanation from the instruction is not so easy and I really would like to do it that way.
    Thanks for your help.
    Jul 2015
    Re: Tsugami - main/back spindle rotation phase synchronisation control
    Email me your contact information, I'll send you the proceedure. The manual is correct, a bit difficult to understand the first time thru. Please note,there must have a keyway in the shaped sub collet, a 3mm pin needs to be inserted into the collet sleeve adapter to pin the collet prior to phase adjustment.
    Rob
    Tsugami/Rem Sales
    Sep 2007
    12
    Did you already send me the document?
  1. Mach3 spindle control/VFD/back gear
    By Johns tool room in forum Mach Mill
    Last Post: 05-12-2014, 07:06 AM
  2. vfd 3 phase spindle on/off control via mach 3
    By Mick Gannon in forum Phase Converters
    Last Post: 07-18-2013, 02:32 PM
  3. Spindle pulse feed back out of control
    By woffler in forum Mach Mill
    Last Post: 08-18-2011, 01:43 AM
  4. How to control the speed of the main spindle?
    By george128306 in forum Hobbycnc (Products)
    Last Post: 04-15-2006, 10:00 AM
