587,997 active members*
2,208 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > I would like to setup XYZ limiter.
Results 1 to 7 of 7
    Jun 2006
    126
    Long story short, due to some design of the machines, I am actively looking to find a way to attach limit switches to SX3 controller box to protect potential further issues I can see down the line. I am bit tired of idea of referecing machine to home for keeping myself safe each time machine is turned off as well as possible mistake i could make.
    Any help would be appreciated.
    May 2006
    1469
    Jinu
    You can make the homing switches to do double duty as limits.
    If you have the Syil setup have a look at this thread to see how I put
    tabs in to activate both ends of travel as limits.
    http://www.cnczone.com/forums/showpo...1&postcount=48
    However I have found that I do not need the limits and use the soft limits in
    Mach instead. The soft limits work very reliably for me.
    You really must reference after powering up. It is the only way to let Mach
    know where everything is. We're only talking short travels so it happens
    pretty quick
    Dec 2004
    54
    What about rotary table? I think, also A-axis will need some homing switch? Or not?
    Regards,
    I.
    May 2006
    1469
    I can't comment on a rotary axis as I don't have one.
    Sep 2006
    203
    A axis does not require any limit switching. If you wanted something on the A axis, you would need some type of switch and trigger attached to some point on the 4th axis rotory table. Could be easy to do, but I really don't see a function of it.
    Direction, Commitment, Follow Through
    Jun 2006
    126
    I am not sure how accurate can such device for a-axis would be to be honest unless direction is limited to one way for checking. When I have some time, I surely will put liiter the way Greolt has set his. That should prevent any mistake I could possibly make...
    May 2006
    82
    Why don't you want to home the machine after the machine is shut down?
