587,171 active members*
2,958 visitors online*
Results 1 to 8 of 8
    Jan 2015
    71
    Face mill help
    On the first operation of a part I need to face off 1/16" of 6061 aluminum. I am using the Tormach 1 1/2" facemill to do this operation. Let me say I am new to CNC so please dont call me an Idiot. lol. I have a few questions about this. On my first attempt, I could not find a way to have the mill start off of the part and lead into it. so it ends ip gouging pretty bad. Also, cutting .0625 in one pass at 5100 RPM and 4 IPM proved to be way too heavy for my machine. Maybe because it is starting on the part therefor causing it to cut with the backside of the tool for a small distance. Please advise me on how to get this to lead in and what would be your suggestions for feeds, speeds, and depth of cut. I really need to get this operation running optimum.
    Aug 2013
    980
    I do those all the time and at the same feed/speed.
    Make sure your plate is secured evenly bit not eccentrically so that the plate bows. This will introduce chatter.
    I always start my face milling with the fm a min of 1 3/4" from plate so I enter and exit the cut from the side.
    What machine are you using?
    Quote Originally Posted by Strip View Post
    Jan 2015
    71
    Re: Face mill help
    I am using a Tormach 1100. What operation do you use in sprutcam to get the fm to start off of the plate. Do you cut the full .0625 in one pass?
    Aug 2013
    980
    I use 2d contour
    I mostly do .03" passes but do 1/16" without a problem unless the metal is not supported well.
    Jan 2015
    71
    Re: Face mill help
    Quote Originally Posted by CadRhino View Post
    I use 2d contour
    Thank you for replying. I guess since my stock is wider than the 1.5" I will have to go in and physically draw lines for the tool path? This will be terrible since I really dislike sprutcams drawing tools. I guess I will have to figure the stepover in to these lines as well. How much step over do you recommend?
    Aug 2013
    980
    I draw all of the lines in cad first and use .05" step over
    Jun 2006
    3063
    Re: Face mill help
    If you use SprutCAM 8, this tutorial may be of interest:
    https://www.youtube.com/watch?v=GB3C0v38DFY
    SprutCAM 10 will be released within a few months and has a specific operation for surfacing that should make this much easier. However I usually just face mill or fly cut manually, either with the jog pendant or with manual commands through the MIDI. Also, I haven't checked yet, but PathPilot (Tormach's fairly new controller may have a conversational wizard for surfacing.
    Nov 2007
    2151
    Re: Face mill help
    Another possible solution is the finish drive operation with settings that work best for your tool type and desired results.
    Your limited to a single pass full depth cut for the most part. There are some drawbacks to this and care must be taken to set everything correct or tool paths might not be generated and or it is easy to get tools going the wrong direction.
    Still with some practice and care I found this to be very usefull and a way to avoid following limited pre-drawn lines
    Copied right from my notebook
    Attachment 292196
    Flycut setup using Finishing plane operation shown below details a way to build same operation with no lines required and you have complete control over size ,approach, departure , angle, axis to get desired finish and control swarf direction even.
    Attachment 292184
    First create a Finishing drive operation in the coordinate system plane your working in. Select and or define the surfacing tool "in this case a fly cutter" Then check or set feeds and speeds.
    Next to setup and control tool paths first set the lead in and lead out to provide tool clearance before start of cut and at end. This example uses .5 inch to generate tool paths half an inch past the end of the part on both approach and at end.
    Attachment 292186
    Next Select strategy tap and set milling type, Step and angle. These can be modified to provide right to left, front to back or angled path over the surface to control your finish or where your chips fly. The example above sets conventional milling with 80 % step and 0 angle. These settings duplicated the above 2d example with no lines and this can be changed as desired.
    Attachment 292188
    Note same operation changing only the angle under strategy changed the tool paths from right to left to back to front. Using this operation and parameters many different tool paths can be generated with no lines that you would have to draw in those locations using the 2d method.
    Attachment 292194
    One more example of the tool paths set at 45 deg angle shows how many ways this can be done and have decent control of tool paths just by changing a few settings. Note tool paths in yellow above .
    As noted above some of these operations when adapted like this can be flakey to use and care must be taken to avoid tool damage!
    Hope this helps some users!
  1. How to drill and face mill using table type horizontal boring mill
    By SatishNaik in forum News Announcements
    Last Post: 10-09-2013, 01:10 PM
  2. Replies: 0
    Last Post: 07-29-2013, 01:15 PM
  3. Which face mill?
    By Iano in forum Benchtop Machines
    Last Post: 07-20-2011, 07:47 AM
  4. Face Mill ?
    By 79TigerPilot in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2010, 05:35 PM
  5. Where to find Shell mill / Face mill arbor for taig
    By 725franky in forum Taig Mills / Lathes
    Last Post: 11-18-2009, 11:48 PM
