588,058 active members*
5,491 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > VIDEO: fixed gantry cnc router build
Page 1 of 2 12
Results 1 to 20 of 22
    Nov 2015
    15
    Greets all.
    I decided to try my hand at a home-built; got my video camera along for the ride too.
    Fixed gantry / Moving bed (Y axis) .. about 36" x 15" (900x400) with 8" (200mm) of Z.
    biggest problem I ran into so far is a suitable spindle.. in the meantime I purchased a
    1.5kW import spindle with VFD but its much too fast (on paper, haven't tried it yet). it'd
    be great to find the head off of a small milling machine.
    Anyway, here's Part 1 for now.. if there's interest I'll post the others as I get through them.
    Oct 2005
    58
    Re: VIDEO: fixed gantry cnc router build
    This was a GREAT video, I am looking forward to part two! I am no expert but the machine looks great too.
    Apr 2015
    82
    very interesting to watch, i hope you do a part 2 as well.
    Nov 2015
    15
    Thanks! Let's hope it works when it's done -- no pressure now huh?
    Nov 2015
    15
    Just a heads up.. here's Part 2 for anyone who might be following along:
    Feb 2005
    829
    That build looks like it is going great!
    Feb 2009
    192
    Looks like a nice heavy machine, good work. Keep the kids involved they are surprisingly more help than you might think and it keeps them from parking in front of the TV.
    Paul
    May 2014
    182
    This is a great video! thanks for sharing. Your son in there is hilarious haha.
    I'm making time to sit down and watch them again as there's a lot I can learn.
    Jan 2013
    9
    What spindle will you be using? Is this for machining steel? Looks awesome!
    Nov 2015
    15
    thanks all.. and that's a great question Ruben -- one I wish I had an answer to. for now i have an ebay 1.5kW air cooled with the huanyang VFD.
    so far it seems to be working okay, but I don't have high hopes. I just used it to cut some 1/16" mild steel sheet to make belt guards.. and have
    since be 'hogging' some aluminum (ER11 collet!).
    part 3 coming soon and you can see it at work.. though my CAM skills are still lacking.
    On the bright side, I'm getting quite good at breaking small end mills.
    Tony
    May 2015
    34
    Aug 2006
    87
    Great videos! I was surprised to see that I am already subscribed to your YouTube channel.
    Jan 2013
    9
    I'll be keeping an eye on this project, mine will have similarities for sure .
    I'm going for a 2.2kW induction 3 phase 4 pole (1500RPM) motor with hitachi x200 VFD or similar, mainly for steel milling. I'll design my own spindle with ER32 collet.
    What are the dimensions of your tubes?
    Would you in hindsight think 100x100x4mm square tubing would be enough in my case with similar frame and 1000mm gantry?
    Are you satified with the linear guides?
    Nov 2015
    15
    My tubing is 60x60x4.. I designed this so a 50# cutting force at the tool tip, center of gantry, full extension (~8" away) would cause less than 0.001" deflection
    in the frame. How good that might be is anyone's guess.. not sure what cutting forces are like (though personally I doubt they're 50#).. keep in mind this is frame
    deflection.. I have no idea whats going on in the bearings / Z axis plates, etc. but so far so good.
    100x100 might be a bit overkill, but if you've got it already.. might look nice, though.. nice and beefy.
    Too early to say about the linear guides, but they seem to be doing their job so far.
    Nov 2015
    15
    Third and last part of the CNC build. There's a bit of a test project at the end, a rubberband rifle for my boy.. starts at around
    26 minutes if you'd rather just skip to see the machine work.
    Thanks for watching.. comment/criticisms always welcomed.
    Mar 2004
    1806
    Very NICE!
    Art
    AKA Country Bubba (Older Than Dirt)
    Nov 2015
    5
    Excellent videos! You really have a talent for making them easy and pleasant to watch. Your kid must be happy
    I'm contemplating a welded steel build myself, albeit with a moving gantry, so it was very interesting to see how you did it.
    Have you done any stress relief after welding? If not, are you worried about things slowly moving out of alignment?
    Have you tried cutting steel thicker than that sheet for the belt guard?
    Cheers,
    Alex.
    May 2005
    3920
    very nice video.
    Looks like your goals have been accomplished and the you have a very stiff machine.
    Jun 2013
    1041
    Great videos. The design is really great. I have to ask. Where did you get the design for the rubber band gun? Is it something you designed yourself? If so great job.
    Ben
    Jan 2007
    219
    Another great video!
    Where did you get the material for the bellows you used?
    -Adam
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
Page 1 of 2 12
  1. Fixed Gantry CNC build log
    By shoot in forum DIY CNC Router Table Machines
    Last Post: 09-13-2019, 10:22 PM
  2. Replies: 17
    Last Post: 10-26-2015, 11:43 PM
  3. New DYI Fixed Gantry Router Build
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 07-06-2015, 12:45 PM
  4. Fixed Gantry - First Build
    By Schweeb in forum DIY CNC Router Table Machines
    Last Post: 04-01-2012, 10:49 PM
  5. Moving table fixed gantry build
    By judleroy in forum DIY CNC Router Table Machines
    Last Post: 12-15-2010, 05:11 AM
