587,772 active members*
3,234 visitors online*
IndustryArena Forum > MetalWorking > Diemaking / Diecutting > die for pressing steel sheet into U shape
Results 1 to 17 of 17
    Jun 2005
    1015
    i need to make a die to stamp a flat peice of steel about .050 thick into a U shape. i need these done consistently and will need quite a few of them. these individual Us then get welded togeter.
    basically i need the die to have a flat bottom about 1" wide and then have a radius in the corners of .25" and then go up the sides about 1.25 inches. the lenght of the die is about 10-12" long.
    i figure that i will need a female and male die to form this, what i don't know about is the spring back of the steel and how to start with making the die. i can bend these by hand but i need consistent uniform results. i would like this to be able to be used in my 20 ton hydraulic press.
    Feb 2004
    361
    I was involved in something similar to this a few years back, they used a three part die with upper follow or squeeze rollers..
    the male top push die was relieved on the sides and the follow rollers would over-bend the sides slightly to achieve a straight side after spring back..
    they also had a lower die follower that applied pressure with a hydraulic accumulator to achieve a flat bottom surface as without it there was tendancy to round the bottom flat while bending..
    that die set _mostly- worked ok with the exception that occasionally it would gall a little and then pull one side resulting in unequal finished arm length..
    afterwards they went to a hossfeld style manual bender with a shop made die, and finished it with a hammer die that was basically two notches at a slight inward angle that compensated for the springback, and a flat top surface to get the proper flat on the center, basically push it down into the notches and smack it with a hammer, surprisingly effective...
    enjoy..
    May 2005
    90
    this is probably kinda what you want im guessing
    i would try to "coin" the radius in the bottom
    to set the material to try to avoid springback
    Attached Files Attached Files
    Dec 2005
    3319
    A real nice die material to use would be O6 tool steel. It machines very nicely, and when heat treated propgerly, will easily hold a 60-62Hrc.
    AND, due to the graphitic nature of the steel, generally speaking, it will pretty much be impervious to galling. It should also have low friction while sliding over the metal thus making it a nice material for deep draw dies. It is not that expensive either.
    Be sure to find someone who knows how to H/T it, preferrably in an inert atmophere or neutral salt. Double temper at LEAST, triple is better. TO really prevent distortion, stress relieve at 1250 for 1.5 hour min per 1" thickness and furnace cool if possible prior to austenitize, Q & T.
    Aug 2006
    36
    Quote Originally Posted by Runner4404spd View Post
    How many is quite a few? A die to form a U shape as stated would cost 15 to 18 hundred. You could have a sheetmetal house with a press brake and gooseneck die form them.
    Mar 2007
    156
    Quote Originally Posted by schiada96 View Post
    Actually this probably cannot be made on a press brake. Even with a gooseneck punch, generally speaking you cannot form a channel on a press brake if the leg heights are equal or longer than the saddle (bottom) width.
    Also, you may have trouble finding press brake tooling with such a large radius.
    But, if you can make some design changes, you can have this done on a press brake with zero tooling costs.
    May 2005
    90
    did ya build or buy anything to do this with yet
    Jun 2005
    1015
    no i haven't made anything yet. since this is just thin sheetmetal, someone else suggested i use oak, to make a die. realistically i probably won't need more than 32 of these.
    May 2005
    90
    oak huh...hmmm
    let me know how that turns out
    Jan 2007
    14
    to form u shap part...
    not a complicated part however for the quantities youve listed a press brake form would probably be better. to acccuractly for a part like this you really need a spring loaded form pad. the spring pressure on this form pad requires a geat deal of pressure (calculated by the bending pressure). in addition adjustment is often needed to dial in part.
    Oct 2006
    18
    press brake sounds like the way to go. If you can find a place locally with a turret press, they can trim the parts to size and form for you.
    May 2005
    674
    This is easily doable on your 20 ton press. Buy the book, "Fundamentals of Press Brake Tooling" from Amazon for about $60, and it should give you all the info you need.
    Bending the U in a single press won't be easy as it's difficult to counteract spring back. It'll be much easier to do this with a regular 90 degree die in two presses (which will of course be less than 90 degrees). The book should tell you how much exactly. You'll need a gooseneck die of course, and it'll be offset from center a bit. Not difficult by any means though.
    As for materials, on a short run with light weight materials, you can probably get by with plain old A36 hot rolled. 4140 prehard would be better though. Tool steel, probably overboard.
    Apr 2005
    460
    U chanels
    RR440 Have the local sheetmetal shop bend one or two part's long enough to cut what you need out of then weld . Are you trying to make a rectangle tube ? I made runner's for a intake manafold with one seam four bend's made a push clevis for my press and a bit that would fit in the confine of the finished part made the bit out of hotroled bar with a radis and cut a grove in 1 1/2 Aluminum for the female with the corect R tool ID. R+mat thickness = Grove R. I kept machining the grove untill the bend was corect when it bottemed out Drilled a series of holes in the edges of the plate to put pin's in for back stop's I think I tryed four times to get the part wright after doing a lot of math calculations to try to save material Good Luck Kevin
    Jan 2007
    14
    32 issuch a low quantity that you mightjust maker the tooling from aluminum . grease the forms when bending the part. you might then use a milling machine vise if thats long enough to bend in the spring back. a block at the bottom of the vise will make the results somewhat consistent. we usually consider this type of quantity prototype tooling. i try not to take too much pride in the tooling and just get the parts bent.
    Jul 2007
    9
    This part you are describing and the quantity would be easier to fab. in a brake press,we have .25 radius brake dies in my shop.
    Mar 2006
    45
    for 32 pieces, send it out to a metal fab shop...
    it'll be cheaper then making a die for it...
    as for scubanicks example it's pretty good, except you'll need a spring loaded pressure pad in the bottom "U" or otherwise the bottom will never be flat...
    it is a simple part, but the pressure pad is needed, also it helps with ejection
    May 2005
    1810
    Fffft! This is for a minimal qty from 18 Ga sheet metal? I would not even think twice about making the die set from Oak.
    Seriously!
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
