588,150 active members*
5,385 visitors online*
Results 1 to 10 of 10
    Pitch balls screw
    Hello everybody !
    I just bought a VM 17 that need a full restoration state.
    I have to change the balls screws and I have difficulty finding in France 4 pitch ball screw (6.35mm per revolution )but it is easy for me to find metric pitch 4.233 (6.00 mm per revolution).
    Do you think it will be possible to modified parameters in Centurion 6 program for a proper use ?
    As this machine will not be reconnected before several months, I can not check now.
    Thanks for help !
    Jul 2010
    548
    Re: Pitch balls screw
    Hi Lauchu, Yes it is possible to use say a 10mm ballscrew. newer Milltronics machine use a 10mm.
    Are you replacing just one screw or all 3 axis? Mixing different pitches in the axis can be problematic. especially in X and Y, may have problmes cutting circles.
    it is possible to get ballscrews repaired/ reloaded. unless it is total junk. have you explored that option?
    If you are needed one, I may have one available. PM me the machine S/N and which axis you need.
    Sportybob
    Sportybob ,
    I have to replace the screws on the 3 axis
    I think they have too much backlash for repair , 0.004 " on x/y and 0.006" on z
    If I understand well , I can change parameters in centurion program for using screws with 6 mm lead
    I agree with you about mixing different pitches
    thank you for your offer and your answer
    Jul 2010
    548
    Hi Lauchu, A couple things think about, rebuilding is about 1/2 the cost of new. they should be able to reload .004 - .006 and get it right. It also depends on the condition of the screw and inside the nut.
    Check the nut dimensions closely, some of these ballscrews had a "smaller" then usual diameter and mounting bolt pattern, standard sizes might not fit.
    What is the serial # of the machine? I will check on ball screw pricing here in the US.
    direct email is ; [email protected]
    about me, go here, www.electromechtechservices.com
    Bob M
    Oct 2015
    32
    Bob,
    How would you go about adjusting the lead screw pitch on a Cen 6 control?
    Thanks,
    Nick
    Jul 2010
    548
    Hi Nick, The control does not "adjust" the pitch of the screw.
    sportybob
    Oct 2015
    32
    Bob,
    I know the control does not adjust the pitch of the screw. I am asking how to change the pitch of the screw in the control. For example, if you currently have 6 mm pitch ballscrews and replace them with 10 mm pitch ballscrews, what parameter do you have to adjust to make the machine run correctly?
    Oct 2015
    32
    Anybody know?
  1. Measuring ball screw bearing balls
    By Bearing Ball in forum Maintenance DIY Discussion
    Last Post: 11-19-2011, 01:59 AM
  2. New balls for screw rod ?
    By vroemm in forum Linear and Rotary Motion
    Last Post: 01-15-2008, 11:55 AM
  3. AFFECT OF MISSING BALLS IN BALL SCREW
    By Khalid in forum Machines running Mach Software
    Last Post: 01-02-2008, 02:59 PM
  4. re-load balls screw to reduce backlash?
    By cncuser1 in forum Linear and Rotary Motion
    Last Post: 10-01-2006, 02:08 AM
  5. ball screw balls
    By Super-Dave in forum Mechanical Calculations/Engineering Design
    Last Post: 02-13-2005, 02:46 AM
