587,372 active members*
3,479 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > mounting US digital encoders
Results 1 to 2 of 2
    Sep 2011
    474
    Ive read through the instructions on how to mount these. They seem to need some pretty specialized stuff and very careful planning.
    So the servo is mounted vertically in a jig on a mill/ drill press, the shaft is centered below the chuck/ collet. Then holes are drilled and tapped .75" from the center on either side, correct?
    These screws used are 0-80 UNF? Can any other, more common sizes be used? I remember reading that 4-40 were being used as well. then the centering tool is used to center the base of the encoder before the screws are tightened, correct?
    The rest is complicated and delicate as well:
    http://www.linengineering.com/wp-con..._Datasheet.pdf
    But it seems even the slightest slip-up can ruin the whole process. Is everyone going through the steps as outlined in the directions?
    I just practiced on a piece of aluminum and was off by a hair, which would have ruined the servo.
    Any advice, tips or tricks?
    Feb 2007
    966
    Re: mounting US digital encoders
    They work with 4-40 screws no problem.
    I made a small jig plate for drilling the (2) .093" holes. It has a reamed hole that fits over the shaft, so i can do a bunch of motors quickly.
    Always use a tapping head for those 4-40's though if you can.
    I also put the encoders on size 23 steppers. They mostly have a 608 bearing so i drill a 1.2" spacing each side of the bearing boss. But i have to also drill new mounting holes in the encoder body since they are a non standard spacing.
    Larry
  1. Installing US Digital encoders without spacers.
    By SwampDonkey in forum CNC Machine Related Electronics
    Last Post: 02-11-2016, 04:00 PM
  2. Serial/digital encoders
    By Eson in forum CNC Machine Related Electronics
    Last Post: 03-27-2013, 10:21 PM
  3. cheap absolute encoders? Oxymoron? Decent Incremental encoders?
    By mattbesquare in forum Benchtop Machines
    Last Post: 09-09-2010, 12:56 AM
  4. Mounting an X3
    By milotrain in forum Benchtop Machines
    Last Post: 02-10-2010, 04:52 AM
