603,319 active members*
2,688 visitors online*
Page 1 of 2 12
Results 1 to 20 of 30
    Feb 2011
    31
    issue fanuc 18i S56 makino
    In our tool data page for our length offset.
    everytime we start any program, the control clears the length data out of 1 and 2 tool data.
    If we try and use T1 T2 ( H1/H2) machine will crash.
    anyone run upon this issue?
    thanks,
    Gary
    Feb 2006
    1792
    Re: issue fanuc 18i S56 makino
    Post the program which clears the length offset data.
    Feb 2011
    31
    That has no effect....... here is what all our headers post out: of course tools and x y 'are different.
    Always G49 (clears offsets, in case tool lengths changed)
    No matter what we do it wipes offset 1 and 2 out to zero.
    O3600
    G49 G80
    T1
    M6
    S3055M3
    G90
    G54
    G0X-4.1725Y-3.75
    G43Z.5H1
    Z.0394
    G5P10000
    M7
    G1Z-.02F36.66
    X-4.135
    G17
    G3X-3.385Y-3.I0.J.75
    G1Y3.
    G3X-4.135Y3.75I-.75J0.
    Feb 2006
    1792
    Do you mean to say that the length offset table has some value in row 01 under H column (Geometry & Wear), but it becomes 0 after you run this program?
    Does this machine have Tool Life Management? It is possible to have Offsets assigned to Tool Life Groups.
    Feb 2011
    31
    It does have Tool Life Management. but its turned off.
    Feb 2011
    31
    Yes. we can enter the tool length as : 5.3254 and it will zero offset 1 and 2 as soon as the machine starts moving.
    Feb 2006
    1792
    There might be some other issue which needs to be identified.
    A program cannot change offset values without using G10 or system variables. And you are not using these.
    Feb 2011
    31
    There is not any G10 commands in our programs.
    I'm not sure about which system variables might be changed, it is a used machine, only been using it 2 weeks.
    Feb 2015
    161
    What is PRM 3290 thru 3295 set?
    Also, when performing a tool change, does the machine jump to another program to change? If so, this macro program could be changing your offset.
    Dec 2008
    3211
    Single step thru the program to identify which line of code does the dirty deed
    Quote Originally Posted by mfain88 View Post
    O3600
    G49 G80
    T1
    M6
    S3055M3
    G90
    G54
    G0X-4.1725Y-3.75
    G43Z.5H1
    Z.0394
    G5P10000 <--- this is a strange G-code to me
    M7
    G1Z-.02F36.66
    X-4.135
    G17
    G1Y3.
    What does the G5 P do ? .....should it be G65 ( a macro call ) ?
    Quote Originally Posted by STLMachinist View Post
    M6 is an actual jump to a toolchange macro
    - you may need to enable the 9000 series programs to read that macro
    Feb 2011
    31
    Soon as it hits the M6 it clears tool data 1 and 2.
    G5P10000 --- set the Fanuc SGI logic on
    where do I check if Macro's are on? having trouble finding it.
    Feb 2011
    31
    3290 thru 3295 are all set to 0
    It does not jump to another program.
    we are not using any macro programs.Attachment 318252
    Dec 2008
    3211
    It should be in your library of the 9000 series.... you need to enable a parameter to be able to view/edit this 9000 series
    - a search says it may be O9000, O9001, or even O9006
    you need to find the parameter that makes the jump to the toolchange macro...one says it is parameter #240....check your manual
    a couple of links
    www.cnczone.com | 404 - Page Cannot Be Found
    http://www.cnczone.com/forums/g-code...nge-macro.html
    Feb 2011
    31
    thought we had it, walked away machine crashed.
    enabled edit 9000.
    still working on it.....
    frustrating.
    Dec 2009
    1118
    3202 NE9
    Feb 2011
    31
    It is set to 1
    Dec 2009
    1118
    It is set to 1
    must be 0 to see the 9000's programs and set to 1 to protect them.
    Is the option bit turned off? What is the value in 9932, 9957, 9985, 9937, 9906, 9995.
    Feb 2011
    31
    can't find 9932, 9957, 9985, 9937, 9906, 9995
    goes to 8343
    next pg down is
    12318
Page 1 of 2 12
  1. Makino with Fanuc controls issue
    By andrewklay in forum Fanuc
    Last Post: 07-18-2014, 05:15 PM
  2. FANUC OMC- MAKINO BN1-85
    By BKCOM in forum Fanuc
    Last Post: 03-03-2009, 04:18 AM
  3. Makino A-55 with fanuc 0m?
    By ALAUDY in forum Fanuc
    Last Post: 05-03-2008, 03:42 PM
  4. Makino MC-86 W/ 11M Fanuc PMC
    By mcrosby in forum CNC Machining Centers
    Last Post: 06-04-2007, 11:12 PM
  5. Makino Fanuc 0-MC
    By DHYSTA in forum Fanuc
    Last Post: 04-07-2007, 01:38 PM
