603,365 active members*
3,861 visitors online*
Results 1 to 3 of 3
    Feb 2013
    27
    Question What is a TB6560-V2?
    Can't seem to find any sites to explain what a TB6560-V2 as opposed to a TB6560.
    Considering these two purchase sources for a kit and wonder what I would be getting for the extra money for the first one with the V2.
    The second one has a bigger power supply and is about $40 less.
    4 Axis 1.9Nm(269oz.in) Nema 23 Stepper Motor & TB6560 Driver Kit|US122|4 Axis CNC Kits
    USA Free Wantai 4Axis Nema23 Stepper Motor 57BYGH633 270oz in 3Axis Driver Board | eBay
    This is for a 1500x1000 OX, for wood, using Mach 3.
    Ox CNC Mechanical Kit - Large - Maker Store USA
    Thanx, Alan
    Feb 2013
    27
    Re: What is a TB6560-V2?
    Found this article about problems with the TB6560 and a fix- [FIX] How to fix Chinese TB6560 Stepper controller - Sonsivri
    Does anyone know if the V2 board fixed those issues?
    Page 2 of the V2 manual.....
    http://us.stepperonline.com/download...ers_Manual.pdf
    ......may answer that question but I don't understand the terminology well enough to know.
    Thanx, Alan
    Dec 2014
    30
    If you mean BL-TB6560 - V2 , it's a single axis driver using TB6560 chip without the breakout circuit that connects to PC parallel port.
    The cnc kits you listed comes with the breakout circuit and motor driver chips (3 or 4 axis) in one pcb.
    The V2 works but it does not have protection diodes at the outputs and the all in one boards too.So check carefully.Plus
    most do not have power sequencing of 5V logic signals ( must come first) and motor 24V supply which can damaged the driver. TB6600 or other varient does not have this
    problem but nonetheless it's good to have protection diodes for backemf from the motors.
  1. TB6560
    By SRH in forum Norwegian
    Last Post: 01-27-2014, 02:08 PM
  2. tb6560
    By nigelcc in forum Stepper Motors / Drives
    Last Post: 04-28-2013, 12:18 PM
  3. TB6560
    By Elektryk in forum Stepper Motors / Drives
    Last Post: 04-02-2012, 04:20 AM
  4. TB6560 are they all the same?
    By Gamble in forum DIY CNC Router Table Machines
    Last Post: 08-24-2011, 07:01 PM
  5. tb6560 help me!!!!!!!!
    By AvioP in forum Stepper Motors / Drives
    Last Post: 08-02-2010, 09:06 PM
