587,517 active members*
2,834 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Aug 2016
    11
    Coordinate System Rotation And Planes problem!
    Hi guys!
    I wrote a macro using coordinate system rotation (g68) and planes (g17,18,19) but I get this error:
    Illegal Plane Selected!
    Can anyone help me?
    #1=0;
    G01 X16 Y0;
    Z-10;
    WHILE[#1 LE 90] DO1;
    G18;
    G03 X36 Z-10 R10;
    G02 X16 R10;
    G17;
    G01 Z1;
    #1 = #1+1;
    G68 X0 Y0 R#1;
    G01 X16 Y0;
    Z-10;
    END1;
    Jun 2010
    4262
    Re: Coordinate System Rotation And Planes problem!
    Exactly what are you trying to do here??????
    A pic might help.
    Cheers
    Roger
    Aug 2016
    11
    1/4 of this shape. (0 to 90 degrees)
    Jun 2010
    4262
    Blimey!
    OK, guessing (because I do not know your controller): the rotation command g68 usually only works in the XY plane. Having issued a g68 command, trying to change the plane away from the XY one is illegal. You will have to program it a different way.
    Cheers
    Roger
    Aug 2016
    11
    the control is Fanuc Oi-MB, and i'm changing plane then use g68 on XY.
    Step 1: G02/03 on XZ plane
    Step 2: Change Plane to XY
    Step 3: Rotate coordinate system
    Does this mean that i am rotating XZ plane!??
    May 2016
    36
    Where you from Amir? What country do you live in?
    Aug 2016
    11
    Quote Originally Posted by postwrtr View Post
    Iran, Why?
    Aug 2009
    684
    Does your machine have the option to arc in three axes? If it does, you may need to add another argument to the G2/G3 to define the midpoint.
    If not, the best way may be to produce the shape in G1 line segments instead of arcs. Just use two more while/do loops inside the existing loop, to travel back and forth.
    Removing the arcs also means you won't have to change the working plane.
    DP
    Aug 2016
    11
    Quote Originally Posted by christinandavid View Post
    DP
    Thank you for your answer, but i have a few questions,
    How do I know that my machine has the option to arc in three axes?
    and logically my code doesn't use three axes unless the machine conclude itself that our main purpose is moving around three axes.
    look, I move into XZ plane, then change plane, move on the XY plane, not three axes in a same time. right?
    and about dividing arcs to straight lines yes I could do that but not a good idea, I need clean code. that is what satsfies me
    Aug 2009
    684
    Quote Originally Posted by amir_nop View Post
    I assume program will run without error if the G68 is removed?
    DP
    Aug 2016
    11
    DP
    Yes it works well without G68.
    Also works by removing G18.
    Jun 2010
    4262
    You don't. I suggest you assume it can NOT unless you find an explicit statement that it can. I don't think NIST g-code allows it, and it would be hell for the older controllers to implement. Read the manual.
    But the controlled point WILL be moving on all 3 axes. Anyhow, I am not going to continue arguing the point.
    Once the machine has executed a single g68 command (without a matching g69), then the machine knows it has entered into coordinate rotation. Once it has entered into coordinate rotation, a change of work plane is not permitted. That is what the error message is trying to tell you.
    Do any controllers permit a change of work plane once you have entered into coordinate rotation? I don't know, but I don't know all controllers. I do know the maths would be fairly complex, and I tghink that you would need a PC-based controller for this, not an older hardware-based unit.
    Cheers
    Roger
    Aug 2016
    11
    Quote Originally Posted by RCaffin View Post
    Isn't this moving on all 3 axes????
    The machine does it easily!
    What's the difference?
    Attachment 330474
    Aug 2009
    684
    Attachment 330474
    Hi Amir,
    Just to clarify, the drawing you attached looks like it is showing a part of a helical slot. The circular component is true to the xy plane. The z motion is a separate linear motion.
    So in the three standard working planes, an arc, even as part of a helix, is only handled by two axes. Arcing in a non-standard working plane is a feature more commonly used on 5-axis machines I suppose. It could be an optional extra on your control but probably not worth paying for.
    So how are you going to program it?
    DP
    Aug 2016
    11
    Hi Amir,
    DP
    Thank you for the information, actually I kinda gave up, it really annoyed me! I was working on it for a whole week standing up to machine and change every line more than 10 times.
    And I'm not convinced yet.. how can our controls be that weak..??
    Anyway there is a way to get it to work and it is dividing arcs to polylines, a little macro could do that easily, maybe someday I wrote it. not on the mood and so busy at the moment :/
    Jun 2010
    4262
    Well, there you go. You can NOT mix G68 and G18.
    Cheers
    Roger
    Aug 2016
    11
    Cheers
    Roger
    ARE YOU SURE??
    or you are just guessing?
    Jun 2010
    4262
    Yes, the hardware can do it. So can mine.
    But the controlling SW (Fanuc, Mach3 or whatever) can NOT do it via G68 and G18. It was too hard for the SW writers.
    In effect, you can imagine more than they could write.
    Cheers
    Roger
    May 2015
    1422
    Be interesting to know if kmotion, uccnc or one of the others out there could cope...
    Oct 2005
    1145
    Mach3 cannot do it Mach4 cannot do it UCCNC cannot do it. The problem is tha the controllers cannot do the G18 arc in rotated space. M3 and M4 TRY to do it but starts teh arc in Rotated space BUT it always ends teh Arc in NON rotated space and teh second arc will be totally in NON rotated space.
    Could it be made to work SURE it can IF they wanted it to BUT I dought you will ever see it done (;-).
    Now that said I believe that Fanuc can do it as it should support a midpoint Value BUT you would have to rewrite teh code and use Arc with IJK not radius values.
    (;-) TP
Page 1 of 2 12
  1. Coordinate rotation problem on MORI SEIKI TV40 MSC-802m
    By kpandy in forum MetalWork Discussion
    Last Post: 08-28-2014, 04:25 PM
  2. G68 Coordinate system rotation.
    By Ashish B in forum CNC Machining Centers
    Last Post: 01-07-2013, 11:14 PM
  3. Coordinate System Rotation G & L NumeriPath 8000B
    By western pa papp in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-05-2011, 01:03 PM
  4. G68.1 Coordinate System Rotation Help
    By SwissPR0 in forum CNC Swiss Screw Machines
    Last Post: 02-03-2011, 08:29 PM
  5. G68 Coordinate Rotation System
    By ebigfoot2 in forum Fanuc
    Last Post: 08-13-2007, 01:33 PM
