603,310 active members*
3,000 visitors online*
Page 1 of 5 123
Results 1 to 20 of 101
    Aug 2016
    3
    Help G54, G55, G56
    Hi
    needsome help. Im runing Hartford matrix VMC-560. I got this problem:
    i would like to write a gcode, to make 3 identical electrodes. When i generate my gcode in solidacm, it is in position g45(default). How to change code, so that when electrode on g54 is complete the machine contntinues milling same electrode on g55 and g56 position.
    This ismy code :
    15362
    Re: Help G54, G55, G56
    Quote Originally Posted by gapy88 View Post
    Hi
    This ismy code :
    You may not even need to use a different offset, where ever you want it to start the next part you can just do a G0 Y0.X100 or what ever the spacing is, if you want to use G55 and G56 then you have to set that in the machine offset page where you want each offset to start, just like when you setup for your G54, work X0Y0 then you do the same for any other offset you want to use
    Mactec54
    1943
    Just saying...That is not ALL he has to do. He then has to re-write the code too.
    15362
    Quote Originally Posted by 109jb View Post
    And is that not what would normally happen, I just gave him different choices 3 ways he could do it in fact, with 2 examples, ( What don't you get ) here is a photo of 400 parts that where machined by just using ( 1 ) offset, 24 parts at a time 2 different vices, all with X Y moves
    Mactec54
    1943
    400 parts, one offset and the code for each part has to be DIFFERENT. What you said is all he has to do is add a move in-between parts. I don't get what you don't understand. Saying all he has to do is add one line between parts is not all he has to do for your method with one offset. He has to change every line of code to make it work that way. Each coordinate has to be changed to reflect the fixture offset for each part.
    The OP wants to use the EXACT same code for each part. To do that he only has two options.
    1. Write the code for the part to use G91 incremental moves, then move to the start location for the next part and then he can run the IDENTICAL G91 part code from there.
    2. Use the G54-G59 offsets. Which entails
    G54
    {Commands to make part} <<<<
    G55
    G56
    {Commands to make part} <<<< These codes with the arrows can all be identical. Identical as in they match exactly coordinate for coordinate.
    His original code was written for G90, so 1 is out unless he re-writes the code to start with. that leaves using G54-G59 offsets. For that he will have to set zero for each work offset (G54-G59) on the machine, but the code for each part is exactly the same, character for character.
    15362
    G54
    G55
    G56
    Nobody that know how to program uses a G91, with what you say he should do is very inefficient, that is why I showed different choices he could do, so this is what you would have, if you used 3 different offsets using the same program, using a different offset is very Inefficient way to do a job like this
    O1
    N1G17G40G80
    T4M6
    M8
    G54
    S3450M3
    G90G0X-.25Y0.
    G43Z.1H4
    G1Z-.5F20.
    Y-1.5F60.
    G3X.25Y-2.I.5
    G1X1.75
    G3X2.25Y-1.5J.5
    G1Y0.
    G3X1.75Y.5I-.5
    G1X.25
    G3X-.25Y0.J-.5
    G0Z.2
    M9
    M5
    N1G17G40G80
    T4M6
    M8
    G55
    S3450M3
    G90G0X-.25Y0.
    G43Z.1H4
    G1Z-.5F20.
    Y-1.5F60.
    G3X.25Y-2.I.5
    G1X1.75
    G3X2.25Y-1.5J.5
    G1Y0.
    G3X1.75Y.5I-.5
    G1X.25
    G3X-.25Y0.J-.5
    G0Z.2
    M9
    M5
    N1G17G40G80
    T4M6
    M8
    G56
    S3450M3
    G90G0X-.25Y0.
    G43Z.1H4
    G1Z-.5F20.
    Y-1.5F60.
    G3X.25Y-2.I.5
    G1X1.75
    G3X2.25Y-1.5J.5
    G1Y0.
    G3X1.75Y.5I-.5
    G1X.25
    G3X-.25Y0.J-.5
    G0Z.2
    M9
    M5
    M30
    Mactec54
    May 2014
    170
    How exactly would that single line of code move the whole prog to a new origin?
    I would have modeled it with 3 and prog it like one part. "Nesting"
    Like mentioned, you need to pick up the origin for the G55 and G56 just like you do for G54. Then just replace the G54 with the G56
    15362
    Quote Originally Posted by chuckorlando View Post
    He obviously has repeated his same program 3 times but it did not move to another location because he had not set it
    The simple line of code works like this instead of having a G55 or a G56 after the first part had cut after Z retract you just use a X Y move to the next position, very simple, and then run the same program again
    Mactec54
    Feb 2011
    353
    i would write it as a subroutine
    this is from a haas control similar to fanuc(may have to be writen as a seperate program then called up )(O1011 instead of N1011)
    N1
    ( 3/8 FLAT ENDMILL DIA. - .375 )
    T1 M06
    S6100 M03 T2
    G00 G90 G54 X-0.156 Y-0.4 A0.
    G43 H01 Z1.
    M08
    M97 P1011
    G55 X-0.156 Y-0.4
    M97 P1011
    G56 X-0.156 Y-0.4
    M97 P1011
    G57 X-0.156 Y-0.4
    M97 P1011
    N100
    G00 Z1. M09
    G91 G28 Z0. M05
    M30
    N1011
    G00 Z0.107
    G01 Z0. F50.
    Y1.3 F72.
    X0.156
    Y-0.4 F72.
    G00 Z1.
    M99
    May 2014
    170
    If he has 3 prog with 3 work off sets they would be identical prog except the g54. So every one would say x1.0 from the origin. So simply moving over would not change the origin for any of them.
    So it runs a prog, you tell it to move over x1.0, run the next prog, it will return right to the orig orig and run the orig prog.
    Every number in the other codes would also have to reflect that change because they all work off their own origins.
    15362
    Not at all it would not have the G54 offset in the next program the X Y move take care of that, I do this all the time, it works works well, and is very simple, here is an example, there are other ways to do this same thing as well
    O1
    N1G17G40G80
    T4M6
    M8
    G54
    S3450M3
    G90G0X-.25Y-.25 ( First Part Start )
    G43Z1.H4
    G1Z-.5F20.
    Y-1.75F60.
    G3X.25Y-2.25I.5
    G1X1.75
    G3X2.25Y-1.75J.5
    G1Y-.25
    G3X1.75Y.25I-.5
    G1X.25
    G3X-.25Y-.25J-.5
    G0Z.1
    G90G0X2.35Y-.25 ( 2nd Part start )
    G1Z-.5F20.
    Y-1.75F60.
    G3X2.85Y-2.25I.5
    G1X4.35
    G3X4.85Y-1.75J.5
    G1Y-.25
    G3X4.35Y.25I-.5
    G1X2.85
    G3X2.35Y-.25J-.5
    G0Z.1
    G90G0X4.95Y-.25 ( 3rd Part Start )
    G1Z-.5F20.
    Y-1.75F60.
    G3X5.45Y-2.25I.5
    G1X6.95
    G3X7.45Y-1.75J.5
    G1Y-.25
    G3X6.95Y.25I-.5
    G1X5.45
    G3X4.95Y-.25J-.5
    G0Z3.
    M9
    G53Y0.
    M5
    M30
    And here is the same program but much shorter
    O1
    M98P2L3
    G92X.95
    M30
    O2
    N1G17G40G80
    T4M6
    M8
    G54
    S3450M3
    G90G0X-.25Y-.25
    G43Z1.H4
    G1Z-.5F20.
    Y-1.75F60.
    G3X.25Y-2.25I.5
    G1X1.75
    G3X2.25Y-1.75J.5
    G1Y-.25
    G3X1.75Y.25I-.5
    G1X.25
    G3X-.25Y-.25J-.5
    G0Z3.
    M9
    G53Y0.
    M5
    G90
    G92X-.85
    M99
    Mactec54
    1943
    The single line move between parts will only work if the rest of the program is written in G91. He has it written in G90, so a single line move like that won't work without G54-G59 offsets.
    To use G54-G59 you need to set zero for each one individually. Then when the next work offset is called it will use the defined zero for that one.
    15362
    Works perfect no G91 needed in any programing like this
    Mactec54
    1943
    Your program is a total re-write, not a duplicating code for identical parts. Sure that will work, if you have a single fixture that holds the multiple parts, but not so easy if you have separate fixtures, or are using separate vises. Your way would require re-writing the code every time, or careful alignment of the individual fixtures/vises if you wanted to set a job up again. G54-G59 won't care if the individual fixtures aren't perfectly aligned and have perfect offsets since each one has its own zero location.
    The guy wanted to know how to use G54-G59 work offsets. The answer to that is not to rewrite the whole program to not use G54-G59. The answer is to tell him how G54-G59 are supposed to work.
    15362
    They are 3 identical parts
    I gave him 2 Choices how to setup his offsets G55 G56 Etc , and how to do it with X Y moves, if you have ever made EDM electrodes, which is what he was doing, then all you need is X Y moves to the next start point, depending on his software as to which way is the easiest for him to do it
    Mactec54
    1943
    I gave him 2 Choices how to setup his offsets G55 G56 Etc , and how to do it with X Y moves,y are 3 identical parts
    It doesn't matter if he is making EDM electrodes, or machined dog dooty, he still needs more than a single move to the next start point. Once the machine move to the next start point, the code coordinates will have to be modified by the offset of the fixture. Look at what is in bold above. That is NOT all that he needs to do.
    Aug 2016
    3
    O1 (0001)
    (KNIFIC 29-AUG-2016)
    (----------- ORODJA -----------)
    (- T#4 REZ. TOROIDNI D11.8 R0.-)
    #4=16 ( --- POZ. ORODJA #4 ----)
    (- T#1 REZ. TOROIDNI D11.8 R0.-)
    #1=13 ( --- POZ. ORODJA #1 ----)
    (- T#3 REZ. TOROIDNI D5.8 R0.5-)
    #3=7 ( --- POZ. ORODJA #3 ----)
    (- T#2 REZ. TOROIDNI D5.8 R0.5-)
    #2=8 ( --- POZ. ORODJA #2 ----)
    G40 G49 G80 G90
    G54
    (- BULL NOSE MILL D11.8 R0.5
    T#4 M06
    S5000 M13
    G49
    (- OPER.: HSR-R-CONT-TARGET-1 -)
    G05.1Q1
    G0 G43 H#4 Z100.
    G0 X-10.439 Y28.326
    G0 Z10.
    G0 Z1.805
    G1 X-10.331 Y28.218 Z1.04 F2000
    X-10.025 Y27.912 Z0.391
    X-9.566 Y27.453 Z-0.043
    X-9.025 Y26.912 Z-0.195
    X-3.627 Y21.514
    G3 X0. Y20.012 I3.627 J3.627
    G1 X19.529
    X20.554 Y19.976
    X21.632 Y19.727
    X22.736 Y19.187
    G2 X23.653 Y18.406 I-3.415 J-4.939
    G2 X23.862 Y18.173 I-4.09 J-3.8
    X27.398 Z-66.346
    X27.55 Z-65.58
    Z10. F6000
    G05.1Q0
    M5
    T#1 M06
    S5000 M13
    G49
    (- OPER.: HSM-CZ-TARGET -------)
    G05.1Q1
    G0 G43 H#1 Z100.
    G0 X-0.702 Y-5.958
    G0 Z10.
    G0 Z1.975
    G1 X-0.718 Y-5.954 Z1.715 F2000
    X-0.768 Y-5.944 Z1.459
    X-0.85 Y-5.928 Z1.212
    X-0.943 Y-5.903 Z1.012
    X-1.057 Y-5.872 Z0.823
    X-1.19 Y-5.837 Z0.649
    X-1.297 Y-5.802 Z0.532
    X-1.412 Y-5.764 Z0.425
    X-1.53 Y-5.722 Z0.33
    X-1.695 Y-5.654 Z0.22
    X-1.87 Y-5.581 Z0.129
    X-2.027 Y-5.505 Z0.066
    Y3.277 Z-66.619
    Y3.193 Z-66.372
    Y3.142 Z-66.115
    Y3.125 Z-65.854
    Z-64.854
    Z10. F6000
    G05.1Q0
    M5
    (- BULL NOSE MILL D5.8 R0.5
    T#3 M06
    S2000 M13
    G49
    (- OPER.: HSR-RESTR-TARGET-1 --)
    G05.1Q1
    G0 G43 H#3 Z100.
    G0 X12.576 Y8.67
    G0 Z10.
    G0 Z4.804
    G1 X12.544 Y8.688 Z4.422 F1500
    X12.448 Y8.739 Z4.055
    X12.291 Y8.822 Z3.715
    X12.08 Y8.933 Z3.414
    X11.823 Y9.07 Z3.165
    X11.528 Y9.226 Z2.977
    X11.207 Y9.397 Z2.855
    X10.871 Y9.575 Z2.805
    G3 X7.523 Y7.507 Z2.639 I-1.068 J-2.014
    G3 X10.966 Y5.6 Z2.473 I2.279 J0.054
    G3 X10.944 Y9.535 Z2.308 I-1.163 J1.961
    G3 X7.523 Y7.589 Z2.142 I-1.141 J-1.974
    G3 X10.894 Y5.559 Z1.976 I2.28 J-0.029
    G3 X11.015 Y9.492 Z1.81 I-1.091 J2.002
    G3 X7.525 Y7.672 Z1.644 I-1.212 J-1.931
    G3 X10.82 Y5.52 Z1.479 I2.277 J-0.112
    G3 X11.084 Y9.447 Z1.313 I-1.017 J2.04
    G3 X7.531 Y7.755 Z1.147 I-1.281 J-1.886
    G3 X10.745 Y5.485 Z0.981 I2.272 J-0.194
    G3 X11.152 Y9.399 Z0.816 I-0.943 J2.076
    G3 XX3.527 Y-3.721 Z-15.222
    X3.507 Y-3.835 Z-14.987
    X3.492 Y-3.917 Z-14.739
    X3.483 Y-3.968 Z-14.483
    X3.48 Y-3.985 Z-14.222
    Z10. F6000
    G0 Z100.
    G05.1Q0
    M5
    G0 G90 G53 Z0
    M30
    Aug 2016
    3
    is it possible to paste 2 another identical program at the end of first one, but just with diferent position (g55) ?
    May 2014
    170
    gaby88 you have 3 totaly different prog for the 3 parts and the second one is a macro. Which is fine.
    In this case though if you took just the first part and the code for it, the only change per part would the G54 to a G55 and G55 to a G56
    In HSM works for multiple origins you put the number in the "multiple work off sets" box on the set up page. g54=1 g55=2 g56=3
    May 2014
    170
    " where ever you want it to start the next part you can just do a G0 Y0.X100 or what ever the spacing is"
    No you can not.
Page 1 of 5 123
