Re: Solid Works Solids importing with gaps and over hang
Try turning off Edge Curves for now. You can easily create them after the solid is imported.
You also didn't mention which file type you're trying to read. Solidworks directly?
If so, have them convert it to .SAT, or .X_T or .X_B
I've had MUCH better luck with ACIS or Parasolid files.
Yes, I know Mcam is supposed to read SW files, but try importing using a neutral file type.
ObrienDave. MasterCam since V6. Gcode since 1983.
The nose you punch today may belong to the butt you have to kiss tomorrow.
