603,993 active members*
3,430 visitors online*
Tompagberg Mach3 settings 09-28-2016, 09:57 PM
ger21 Re: Mach3 settings 09-28-2016, 10:16 PM
Tompagberg Re: Mach3 settings 09-28-2016, 10:30 PM
ger21 Re: Mach3 settings 09-29-2016, 01:20 AM
    Sep 2016
    Mach3 settings
    I´m trying to setup my newly bought cnc machine. I have a Proxxon MF70 CNC and a control box from a company called Gocnc.
    I´m having some trouble figuring out how to get contact with the motors, I have watched the tutorials and I´ve set up Mach3 as they say in the video but I can't get my motors to move :/.
    I have attached a few photos and maybe someone might see whats wrong. One thing that I think look strange is that not all pins are green in the diagnostics tab.
    Sorry, that this is probably a very basic question. But I have very little experience with CNC´s.
    Thank you!
    35494
    Re: Mach3 settings
    Do you have the correct port address in Config > Ports and Pins?
    Sep 2016
    Re: Mach3 settings
    Thank you for your answer!
    Yes I believe so. At least for the motors X,Y and Z (direction and step), I´m not to sure where and what the other pins do or should be connected, for example: Input and Output
    35494
    Re: Mach3 settings
    No. When you go to Config > Ports and Pins, there's an address for the parallel port itself. The default is usually 0x378. Make sure that it is the correct address for your parallel port., and that Port #1 is enabled.
  1. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  2. joe's 06 cnc router - need mach3 settings!
    By bp092 in forum Joes CNC Model 2006
    Last Post: 08-18-2008, 08:08 PM
  3. Mach3 Settings
    By studysession in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2007, 01:51 AM
  4. Can someone help with Mach3 settings?
    By Revtech in forum DIY CNC Router Table Machines
    Last Post: 07-23-2006, 08:40 PM
