588,556 active members*
4,908 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Need help with stepper motor connections
    Dec 2016
    Talking Need help with stepper motor connections
    Hi guys,
    I am new to motors and drives. Recently, I would like to try a project with multiple stepper motors. I am trying to connect the stepper motor as shown in the diagram.
    http://www.cnczone.com/forums/attach...d=342730&stc=1
    Motor A: http://www.omc-stepperonline.com/dow...HS13-0804S.pdf
    Motor B: http://www.omc-stepperonline.com/dow...S16-2004S1.pdf
    Motor C: http://www.omc-stepperonline.com/dow...HS24-2104S.pdf
    Will there be any problem with the connection? Any suggestion is welcomed.
    Thank you.
    Best Regards,
    Qzai09
    Apr 2004
    5762
    Re: Need help with stepper motor connections
    What are you trying to build? All those motors are quite small for CNC work, but they might be useful for some things - except motor "C", which, with its 10 mH inductance, probably won't even turn at 24v. Using the formula 32* (sqroot)mH, that motor really wants over 100v to run at top speed, which is a lot more than your arduino will tolerate.
    Andrew Werby
    Website
    Dec 2016
    Quote Originally Posted by awerby View Post
    Hi awerby,
    Sorry for forgetting to mention the project. I am working on a 3 axis turntable. Something like this but a smaller version. https://www.youtube.com/watch?v=DHUWJlAAyqU .
    However, there is no particular forum for this and stepper motor I used is used in CNC machines as well, so I thought here is a good place for me to ask this question. Sorry if I am asking this at an inappropriate place.
    Sadly to say, I did even know the formula 32* (sqroot)mH before you told me, however, if my load is low,
    Motor A's load = 150 grams
    Motor B's load = 300 grams
    Motor C's load = 1.5 kg
    and the speed is around 60 rpm. Can they operate under this condition with Motor C is driving Motor B while Motor B is driving Motor A?
    Besides, I thought the one handling voltage is stepper motor driver? Will it destroy my Arduino with high voltage supplied to my stepper motor driver? However, 100 V is clearly over the maximum voltage acceptable by my stepper motor driver.
    Thank you for your help.
    Best Regards,
    Qzai09
    Mar 2015
    11
    Use the highest voltage your driver can reasonably accept and is practical, anything less and you are shooting yourself in the foot. The difference in performance between a 24 volt and 36 volt power supply is substantial.
  1. hel with DC motor drive connections
    By leandrot in forum CNC Machine Related Electronics
    Last Post: 06-04-2010, 08:15 PM
  2. Stepper motor connections
    By muddobber76 in forum Vertical Mill, Lathe Project Log
    Last Post: 11-17-2009, 04:06 PM
  3. Stepper motor connections
    By muddobber76 in forum Controller & Computer Solutions
    Last Post: 10-12-2009, 06:18 PM
  4. Please help, 8-wire stepper connections
    By Spiral_72 in forum Stepper Motors / Drives
    Last Post: 05-29-2009, 07:38 PM
  5. stepper motors run one-way only ? connections ?
    By pavel59 in forum Mach Software (ArtSoft software)
    Last Post: 09-09-2007, 02:15 PM
