587,180 active members*
4,852 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > New Table trying 1st cut - Home/ travel are in the position I need letters backward
Results 1 to 3 of 3
    Aug 2016
    4
    Hello,
    I just finished my table and got it running. I have to home in the back left corner due to space issues. I thought I had it oriented right, but I dont so I switched the homing direction. The problem is when I cut letters in the Y axis (long direction of the table) it is carving them mirrored. I will attach images. Is there anyway to keep its home in the back left but not carve backwards without reversing the whole gantry? I have tried to figure it out, but no change.
    Nov 2012
    1270
    Re: New Table trying 1st cut - Home/ travel are in the position I need letters backwa
    First, reverse the Y axis motor so the machine cuts true un-mirrored letters.
    Then just tell your control software that your Y homing switch is at Y=1000 (or whatever your Y axis travel is).
    You did not say which program you are using. If it's Mach3, here is my machine's configuration to give you an example.
    Attachment 344160
    On the X and Y axes, the home switches are at 0 - so the "Home offset" is 0 and the "Home Negative" is on.
    On the Z axis, the home switch is at Z=60. Hence the "Home offset" is 60 and the "Home Negative" is off.
    I have yet to figure out what exactly Art meant by "Reversed". It seems that this parameter just needs to stay off no matter where your switches are.
    Aug 2016
    4
    Thank You very much!
  1. Can't home Z 500 over travel alarm
    By adamant in forum Hardinge Lathes
    Last Post: 11-27-2019, 06:15 AM
  2. Replies: 1
    Last Post: 04-07-2015, 08:07 PM
  3. Setting Home Location, Table Travel, and Home Switch Location in Stepconf
    By northbear in forum LinuxCNC (formerly EMC2)
    Last Post: 08-25-2013, 05:07 AM
  4. Replies: 0
    Last Post: 04-08-2013, 03:16 AM
  5. Replies: 4
    Last Post: 10-28-2009, 06:39 AM
