588,165 active members*
4,574 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Stepper Sizing: G0704 Question:
Page 1 of 2 12
Results 1 to 20 of 24
    Nov 2016
    7
    I'm working on converting my G0704 over to CNC like many others and have a question on the stepper sizing.
    I purchased Hoss's plans and have a few questions.
    The 570 oz/in steppers recommended for x and y fall off to only .5Nm at 600 rpm or so and with a 5mm lead that is at around 120 inches per minute travel.
    I see people showing travel speeds of near 200 ipm where this motor has a torque of around .4Nm.
    It seems that the 425 oz/in steppers would be better sized for the unit with a torque at 120 ipm of 1.2Nm and .5Nm at 200 ipm.
    The sacrifice would be start up torque going from 3.1Nm to 2.2Nm.
    The force developed on the lead screw is about 750 lbf at 100 rpm rating for the 425oz/in motor.
    I've read lots of threads on stepper sizing.... bigger is better, bigger isn't always better etc.
    Has anyone tried both steppers and have some real world info?
    I'm looking at using the 16mm ball screws for X, Y, and Z with a custom double nut setup.
    Thanks for the help.
    Nov 2009
    4415
    Re: Stepper Sizing: G0704 Question:
    The same person who spec'd that stepper has many video of him hogging. Not enough?
    A lazy man does it twice.
    1943
    You are looking at torque curves that were obviously derived by different people. When comparing the two that look the same and that would therefore probably have been made and torque measured by the same methods. When you do that you see the attached plots that show at 600 rpm the 570 puts out about 1.5 Nm and doesn't drop to below 0.5 Nm until 1100 rpm.
    Attachment 344666
    Nov 2016
    7
    Quote Originally Posted by 109jb View Post
    Attachment 344666
    Here is the torque curve I was looking at from Automation Technologies
    1943
    Quote Originally Posted by Green_Gord View Post
    Like I said, just the fact that the plot you used looks different raises the question of whether the torque measurements were done the same. The plots I posted were also from automation tech, but the 570 plot was for the 1/4 shaft motor. This should not make a difference in the torque curves so one of them is wrong. Basically what I am saying is that the plot you looked at may not be right. The plot I used may not be either, but it looks the same format as the 425 plot, so at least they should be an apples to apples comparison. The plot I posted shows the 570 will have more torque than the 425 at ALL rpms.
    Nov 2016
    7
    No I think the 570's will work... There is a ton of information and opinions out there.
    My question is the theory behind the 570's is it to give more torque when hogging at slower feed rates and live with the fall off in torque while you are doing rapid movements because the torque isn't needed?
    Nov 2009
    4415
    Though you do see some videos of many of us doing speed trials (I have one at 331 IPM). Those speeds are never really used. In my case if I approached 60 IPM in cutting I would be surprised. I would like to but it isnt feasible. The big machines that do cut at 200-300 IPM or more, rapid at 600-1000 IPM ;-) I think you are correct on the reason as to why the stepper is sufficient.
    Sep 2005
    1195
    Today NEMA 34 1600 oz in or NEMA 23 650 oz in are cheap and affordable, why not use big torque motor plus ethernet...ESS or UCCNC...
    1943
    Quote Originally Posted by asuratman View Post
    Those motors would work, but would be overkill. With 570 oz-in motors I can rapid at 200 IPM and I can take a heavy enough cut at normal cutting feed rates to stall the spindle and snap off a 1/2" end mill before losing steps.
    Nov 2016
    7
    Are you using a 570oz-in motor on the Z or something else?
    1943
    yes. 570 on z and no problems with the stock spindle. I can stall the stock spindle with the 570. With more spindle power you may need a bit bigger on the Z, but the Hoss recommended, which if I remember right is a 960 oz-in is as big as would ever be needed.
    1943
    Forgot to mention. Since it doesn;t drill larger sizes that well, I just drill about a 1/4" hole and open it up with an end mill and circular interpolation.
    Nov 2016
    7
    Okay now for the stupid question...
    Automation tech offers two 570oz-in motors a 4 wire and a 8 wire, the 8 wire has the torque curve that "looks" better with a more normal fall off with rpm and the 4 wire has a pretty flat torque curve for the first 400 rpm or so.
    400 rpm is about 80ipm
    The motor with the better torque curve (8 wire) has 1/4" shafts out both ends while the one that falls off at 400 rpm has 3/8" shaft any issues with the 1/4" shaft and the coupling? 1/4" shaft seems kind of small / hard to keep from turning in the coupling over time.
    Thoughts? or is there a better motor out there?
    Like the others have said, you aren't going to be cutting at 150ipm with this machine. The fastest I cut is maybe 90 ipm but that's rare. 25 to 70 ipm is the common range. Sure my rapids are 180 ipm, and I could probably get 200 or 225 from it, but there's no reason to. The bed is only 20 inches long so it's not like the machine is wasting a bunch of time running end to end, there just isn't enough travel to worry about it. The high torque larger steppers are better at direction changes (i.e. Near zero RPM), and when handling the inertia of the the table, part, fixturing, that's likely the highest loads the stepper sees, barring tool crashes.
    Nov 2016
    7
    That makes sense thanks for the reality check on feed rates.
    Nov 2009
    4415
    The Z wont be moving very far at a time except during homing or a tool change. Even in 3D the travel will be minimal. Though I run a 34/960 IIRC on the Z, a 570 would likely be fine.
    Nov 2009
    4415
    I dont have any issues with couplers turning on either shaft size. Get good couplers! Not the spiral cut aluminum ones.
    Get the four wire, it's easier to solder up by a handful of connections.
    Feb 2008
    521
    Quote Originally Posted by CL_MotoTech View Post
    Seriously? Cutting and twisting two wires into one isn't rocket science. If you've got to solder wires into a connector it makes no difference IMO
    Quote Originally Posted by kawazuki View Post
    Simmer down, I was obviously being cheeky.
Page 1 of 2 12
  1. Replies: 9
    Last Post: 10-09-2016, 10:56 AM
  2. stepper sizing
    By ellobo91 in forum Linear and Rotary Motion
    Last Post: 04-28-2015, 09:02 PM
  3. Question on Stepper Motor Sizing
    By wkps2007 in forum DIY CNC Router Table Machines
    Last Post: 03-05-2011, 01:15 AM
  4. Stepper Sizing Question
    By TDukes in forum Benchtop Machines
    Last Post: 01-12-2007, 01:21 PM
  5. Stepper sizing
    By callcbm in forum Stepper Motors / Drives
    Last Post: 12-25-2005, 10:47 PM
