587,698 active members*
3,226 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
Results 1 to 3 of 3
    Dec 2016
    11
    I’m trying to use an 8 wire stepper motor (which I cannot find the data sheet for) and connect it to a TB6560 Stepper motor driver.
    Shinano Kenshi
    STH-53D400
    133919-001 Rev A
    1.8 Degree/Step 2.4V @ 3.2A
    The pair of wires are as follows:
    Brown / Blue
    Green / Red
    Orange / Black
    White / Yellow
    On a breadboard for a unipolar setup, I can connect the Blue, Red, Black, and Yellow wires together and apply positive voltage to them. I then apply a negative connection to the Brown, Red, Black, and then Yellow wire, the motor moves counterclockwise.
    On the TB6560 Stepper motor driver, there are slots for B-, B+, A-, A+ for the motor and positive and negative for the power supply.
    My question is, how to I take this information from the breadboard and apply it to the motor driver?
    I'm planning on doing testing between unipolar and bipolar configurations, but right now am trying to just get something working.
    Dec 2016
    11
    Re: Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
    From this page, Slowing 69.16.243.61&c=1&t=42734.878369213, I determined the following:
    Blue: A+`
    Red: B+`
    Black: A-
    Yellow: B-
    Brown: A+
    Green: B+
    Orange: A-`
    White: B-`
    May 2005
    1397
    Step 1: Throw away the TB6560 and buy a real driver.
    Glad you got it figured out.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. how do you connect an 8 wire stepper motor to a motion control board
    By mrputz1 in forum Stepper Motors / Drives
    Last Post: 10-23-2015, 12:31 PM
  2. Help to connect 8 wire stepper motor
    By none in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-26-2015, 12:06 AM
  3. To identify stepper motor pin out!!and connect to easy driver.
    By Topicawox in forum Stepper Motors / Drives
    Last Post: 09-24-2012, 09:46 PM
  4. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  5. Replies: 2
    Last Post: 03-29-2008, 03:43 PM
