587,997 active members*
1,522 visitors online*
    Dec 2016
    Question DSP, Mach3, NC Studio or something else
    I am getting ready to order my CNC Router from China.
    Not sure what controller I should get. I thought DSP at first. Then read some negative things
    Looked at Mach3 but have read that if I comes China t will not work right.
    All of you with Chinese machines what do you use and why did you chose it
    I am using Aspire software.
    Nov 2016
    8
    Re: DSP, Mach3, NC Studio or something else
    I got with NCSTUDIO I've heard it depends on your machine type. Mine has 3 spindles and hAve read best supported. Major draw back is lack of good tutorials. In that aspect if singke spindle and novice machinist...mach3 is the way to go.. Good luck witg getting machine that was the biggest hassle for me
    AllenOmnicnc Guest
    DSP controller :
    DSP remote control system is totally independent from PC platform (It does not need PC when the DSP works), directly read files from U Disk,easily process G code or PLT file with any size.
    It supports high micro step which makes precise and fast process possible. Support to process part of the file.Reliable data protection and recover function.
    Mach3 and NCstudio controller
    Mach3 and Nc sudio controller all need the PC to control the CNC machine. Mach3 controller is popular in USA, Canada, Euro, and Australia.etc.
    NCstudio controller is China’s CNC controller, popular in China, South Asia, and India .etc.
    All in all, So if any of your technician used to operate one of 3 above controllers, then please choose one.
    If one of your technician used to operate above, so please choose DSP is ok, as it is easier to learn compare to other CNC controllers.
    AllenOmnicnc Guest
    DSP A11 is for 3 axis,DSP A18 is for 3 axis +rotary ( 4 axis 4 linkage), DSP A15 for multi spindle cnc router. DSP A57 is for linear type tool change ATC cnc router.
    Mach3 with USB
    There are origin Nc studio card and copy card.
    Attachment 345448
    Attachment 345450
    Attachment 345452
    Attachment 345454
  1. Nc studio
    By Dchris01 in forum Chinese Machines
    Last Post: 02-13-2016, 12:35 AM
  2. Need Working Mach3 SDK for Visual studio 2010
    By ephobb in forum Mach Software (ArtSoft software)
    Last Post: 10-09-2015, 02:56 AM
  3. NC Studio to MACH3
    By Mysty_FR in forum Mach Software (ArtSoft software)
    Last Post: 03-25-2014, 09:14 PM
  4. NC Studio or Mach3
    By zac123 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-02-2012, 01:39 PM
  5. NC-studio vs Mach3
    By jallitt in forum Chinese Machines
    Last Post: 11-06-2011, 08:53 AM
