588,672 active members*
6,278 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > code for actual operation accordingly to next operation
Results 1 to 2 of 2
    Jun 2015
    4171
    hello guys please consider a lathe with live tools, thus turning and milling axis : S + M
    there is a situation where code for
    one operation must be created accordingly to next operation
    for example, if operations are :
    ... S,S or M,M, thus same operations, one after another, than
    code_type_1 should be generated
    ... S,M, thus milling after turning, than code_type_2 should be generated
    ... M,S, thus milling before turning, than code_type_3should be generated
    so, is it possible to generate code in this manner ?
    also, if yes, is it possible to generate code for "last operation"
    accordingly to "1st operation" ? this is good when program is looped
    code variants are :
    ... type 1 : G00 X=contast Z=constant M203
    ... type 2 : G00 X=contast Z=constant M203 M05 M63
    ... type 3 : G00 X=contast Z=constant M203 M109
    please, answer even if not possible kindly !
    Jun 2015
    4171
    Re: code for actual operation accordingly to next operation
    how many types of returns do you use ? ( turret to safe position after operation finished )
  1. View actual tool in each operation!!!!!!!
    By oscar_21 in forum Tree
    Last Post: 12-02-2016, 05:59 PM
  2. visual quick code operation
    By hotrunner24 in forum Haas Visual Quick Code
    Last Post: 02-12-2015, 05:51 AM
  3. m code or operation manual
    By rathi_vk in forum CNC Machining Centers
    Last Post: 10-10-2014, 08:53 PM
  4. G-Code Spindle Operation
    By SyilAmerica in forum Syil Products
    Last Post: 03-07-2007, 09:09 PM
  5. Generate G-Code for end-milling operation
    By vijaychd in forum G-Code Programing
    Last Post: 06-02-2005, 09:46 AM
