587,999 active members*
2,730 visitors online*
Results 1 to 8 of 8
    Mar 2017
    3
    Anilam 6000M control
    I am in need of some know how!
    No sure where to start, the controller on cnc mill Quantum S1000D with Anilam 6000M control has a problem it starts up and go to the menu when I select any of the three choices it goes in and freezes up, I can not go back or do anything and the word halted is in the command bar. Any ideas what I should do will be greatly appreciated.
    I have posted a video of the startup.
    Mar 2017
    3
    Re: Anilam 6000M control
    Quote Originally Posted by FranschTech View Post
    Jan 2013
    8
    has the machine been running recently? Normally, when you get to the screen pictured, you have to reset the servo... ( estop out then press servo reset) then press the f-key for home to home the machine, then you will get the manual screen, and can go into the programs... dave
    Jan 2013
    8
    Check to see if you have 24vdc for the e-stop and limit switch circuit... then check all limit switches, for a stuck switch or bad wire connection... dave
    Oct 2011
    38
    I know this is a year old but did you ever find a fix or help? A friend of mine is having the same problem.
    Mar 2017
    3
    Thanks Dave
    I have been away and working on other projects,
    I tried to reset the servo but no response, I have found that the drives have a power fault light on and SH2 lamp on each drive. Any ideas how to go about this?Attachment 369018
    Oct 2023
    5
    Thanks Dave
    Check out my repair here it fixed my machine on Practical machinist
    Search for Anilam 6000M Inverter Repair
    Oct 2023
    5
    Did you solve your servo problems? I have just fixed my inverter
  1. Anilam 6000m controller
    By anilam in forum Controller & Computer Solutions
    Last Post: 02-18-2016, 07:44 AM
  2. Post for Anilam 6000M for inventor HSM
    By bmtrimp in forum Autodesk Post Processors
    Last Post: 03-30-2015, 02:34 PM
  3. Anilam 6000M Halted during G84
    By hadulzo in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2012, 03:52 AM
  4. anilam 6000m
    By slug in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2009, 07:39 PM
