587,751 active members*
3,103 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma MC-4VA - 201-Z Alarm A Servo Amp 2E6
Results 1 to 3 of 3
    Feb 2014
    11
    I've got an Okuma MC-4VA with a "201-Z Alarm A Servo Amp 2E6" alarm that I can't get it to reset.
    - There is a page for Alarm "201" "Alarm A", however I can't find anything about a "201-Z" or "Servo Amp 2E6".
    Opened up the rear box and there are no lights on on the Z-axis "BL-D(30)A" control board.
    There IS power going to the connectors from the DC-Power Supply board, regardless of whether the breaker to the right of the DC-PS is turned on or off.
    - However, the voltages do seem to vary once the breaker is turned off.
    According to the manual, if when the breaker to the DC-PS is turned off and the green light stays on, then the DC-PS needs replaced.
    A few questions that I can't seem to find through searches or the manuals:
    - If the DC-PS is bad, how is it still powering X & Y?
    - Is there a way to double check the DC-PS to know that's what is at fault?
    - Is there a fuse on the DC-PS that I should check?
    - Can a bad motor cause the above error?
    Attached Thumbnails Attached Thumbnails 20170602_072650.jpg   20170601_092954.jpg   20170601_175934.jpg   20170601_175944.jpg
    20170601_162722.jpg   20170601_113300.jpg   20170601_095156.jpg   20170601_174826.jpg
    Feb 2014
    11
    Re: Okuma MC-4VA - 201-Z Alarm A Servo Amp 2E6
    Talked to a tech and they suggested that if the DC-PS had lights that it'd be the Z-axis drive.
    I had it quoted at something just under $5k. Checked on Ebay and found a Y-axis for around $700. All the numbers matched the Z-axis.
    I purchased and installed it and it's now currently running.
    Anyone know of any good places to repair the old drive?
    Aug 2012
    164
    We do the BL-D series; we provide full 1 year warranty, all drives are fully tested in our simulators prior to being placed in inventory (for stock items) or returned to the customer (for repaired items). You can reach me at [email protected] and I can provide you with repair/exchange details and cost. We can also provide full tech support on Okuma machines and controls.
  1. Replies: 27
    Last Post: 02-09-2022, 05:10 PM
  2. Replies: 0
    Last Post: 11-07-2016, 11:44 AM
  3. okuma howa 4va spindle servo 94 alarm 6m
    By moharj in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-31-2015, 03:48 PM
  4. OKUMA LB10 SERVO ALARM
    By BRUTUS 01 in forum Okuma
    Last Post: 04-23-2012, 12:45 AM
