588,342 active members*
5,336 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Step direction signal converted to CW-,CW+, CCW-, CCW+
Results 1 to 15 of 15
    Dec 2012
    9
    Ok, so I'm rebuilding my 3d printer and I've come across a compatability issue. My controller has step/dir output pins. The drives have the CW-,CW+, CCW-, CCW+ inputs.
    I haven't been able to get this to work correctly.
    First I tried,
    cw- and ccw- together going to ground
    cw+ to step signal
    ccw+ to direction signal
    On controller connector I have
    Pin1 = step
    Pin3 = direction
    Pin2 and pin4 ground to pin 18
    Like this the motor runs quickly one direction but very slowly the other direction.
    It also travels less in the slow direction.
    I undid all that.
    Then I,
    Set Parameter 4 to 1
    I have a DC DC converter going from 24vdc to 5vdc. The positive side of 5vdc output runs to CW+ and CCW+ (pins 1 & 3)
    The step signal is run to CW- (pin 2)
    The direction signal is run to CCW- (pin 4)
    The motor runs one direction until it crashes. No matter how far I tell it to go. Nothing happens in the other direction.
    So I'm at a loss. Pleeeeease help.
    If I'm understanding it correctly some people have used some sort of logic gate based circuit. Unfortunately for now, that's just over my head.
    The board is a azteeg x5 gt
    The drives are stonker (China)
    Basic component files are attached.
    Attached Thumbnails Attached Thumbnails Step-servo motor System(en).pdf
    Attached Files Attached Files
    Mar 2007
    2083
    Re: Step direction signal converted to CW-,CW+, CCW-, CCW+
    this old thread may help :-
    http://www.cnczone.com/forums/mach-4...ml#post1931922
    from the post
    Attachment 364794
    Attachment 364796
    Attachment 364798
    It will be easier to find the later 74HCT00 than the original 7400 that dates from the 1960's
    just make sure you get the 14- PDIP version
    (= plastic 14 pin package with pins that fit the 0.1" grid found on vero / perf board
    its easier to start with than the 14-TSSOP used on surface mount PCB's )
    https://www.digikey.co.uk/product-de...081-5-ND/38232
    john
    Dec 2012
    9
    Hey John,
    Thanks for the info. I want to make sure I'm understanding correctly. My drive had 4 inputs. The 7400 diagram is showing only two out puts?
    Mar 2007
    2083
    you have 2 opto-isolated inputs : - step clock wise and step anti- clock wise
    connect the plus CW & CCW to +5V
    the negative CW to pin 11 of the 7400
    and the negative CCW to pin 6
Name:	connections to   CW & CCW inputs.jpg
    John
    Dec 2012
    9
    Thank you sir, I'll give that a go and post my results.
    Mar 2007
    2083
    thats OK
    If it helps you to visualise how it works
    Attachment 364836
    what type of prototype board do you intend to use ??
    this is one version available
Name:	RadioShack perf board.jpg
    John
    Dec 2012
    9
    Thanks again John. I got some little boards but it looks like the one u posted would have been easier.
    Dec 2012
    9
    Ok so is there any reason why the nte7426 ic would not work? I attached the info.
    I also attached a sketch of how I wired it. It is mirrored to make it easier on me.
    With it done this way the motor constantly rotates clockwise. If I jog + it continues to rotate. If I jog - it still rotates clockwise but slower. Any ideas?
    Mar 2007
    2083
    I would of thought it would work with a 7426
    the only difference is the 7426 has open collector outputs that can only sink current to ground
    what happens with no connection to the servo driver inputs ?
    what happens with 5V connected to just the CW input
    then with 5V connected to just the CCW input
    it should only move with step pulses to one input
Name:	connections to 7426.jpg
    John
    Dec 2012
    9
    Not sure if this matters but I'm using a dc-dc converter to go from 24vdc to 5vdc and then pulling ground and +5vdc from there. Also motor is spinning on its own on system power up before the controller board is connected.
    If I remove the connection from from the drive nothing happens connected or not connected to controller.
    With +5vdc connected to CW+ and not connected to CCW+ nothing happens and same for vice versa.
    Mar 2007
    2083
    if this is how you have wired the control
    Attachment 364914
    then the only thing I can think of is the DC / DC converter may be the problem
    if it can not supply enough current to every thing
    John
    Dec 2012
    9
    Would you mind posting a link for the 100uf and .1uf so I can make sure I am getting the correct components?
    Dec 2012
    9
    Hey John, nevermind linking parts for me. I believe I've got it now. Thanks to you my new best friend. Lol.
    Mar 2007
    2083
    only just read your post ,
    its taken a while to un-install the last windows up date and then have a go re-installing them
    you know how it goes when it installs too many at once
    the capacitors don't need to be exactly the values in the diagram
    the electrolytic can be 100uF to 470 uF , 10V to 25 V what is easiest to find
    the usual practice is to connect a 0.1 uF 50V ceramin capacitor across the 5V supply to every 1 or 2 TTL IC's
    placing the capacitor close as practical to the supply pins
    seeing your location
    I guess you have looked at local suppliers
    like Mouser Electronics Mouser Electronics - Electronic Components Distributor
    or Allied electronics inc Allied Electronics - Industrial Automation & Control Products Distributor (RS Components in USA )
    I usually start with Farnell or RS Components in the UK
    John
    Dec 2012
    9
    Actually I have a Fry's electronics store down the street. I lucked out with them actually having something I need finally.
  1. Step direction signal converted to CW-,CW+, CCW-, CCW+
    By ok engineering in forum CNC Machine Related Electronics
    Last Post: 06-13-2017, 03:36 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. Replies: 4
    Last Post: 09-10-2013, 04:52 AM
  4. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  5. Turbocnc direction signal help?
    By giggler in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-17-2007, 06:12 PM
