603,785 active members*
18,112 visitors online*
Results 1 to 8 of 8
    Sep 2013
    131
    Faceted Radius cuts
    Hi all, My Probotics Meteor Fireball router with Mastercam. my process is great I think, but results are horrid. My federate is good, but my endmill won't fallow my profile around any of the rads. Real choppy. Is there a stepper setting on the router to fix this?. My cut tolerance on Mastercam is .0005. Any help would be great, thank you.
    Apr 2004
    5950
    Re: Faceted Radius cuts
    Did you produce this toolpath from a mesh model with a very low polygon count? What it looks like is that the program is faithfully following the profile, but the profile is coarsely triangulated. I don't think it's due to your tolerance setting in MasterCAM, but probably relates to a setting in the original CAD program.
    Andrew Werby
    Website
    Sep 2013
    131
    Hi, I made a silhouette boundary from the solid, I might need to fix my model somehow.
    35494
    Could be the tolerance setting in LinuxCNC maybe?
    Sep 2013
    131
    I think it's my model/ wireframe geometry, I just made some radius geometry from scratch, and it cut perfectly. Thank you for the help.
    Mar 2008
    684
    Was that the model I did a while back?
    Sep 2013
    131
    Quote Originally Posted by warrenb View Post
    Hi Warren, I wasn't able to use yours, sorry. Volute on the head was different.
    Apr 2009
    5516
    Use 2D toolpaths to cut profiles, and save the 3D toolpaths for contouring (surfacing)... Mastercam should output arcs in 2.5D no problem, but most every software will do 3D toolpaths with point-to-point moves.
  1. Fanuc 0i-MD - Faceted with AICC 2
    By popex in forum Fanuc
    Last Post: 07-10-2015, 10:44 AM
  2. Does tool life vary with interrupted cuts to continuous cuts
    By acejunker in forum MetalWork Discussion
    Last Post: 08-08-2014, 02:34 AM
  3. toolpath is too faceted.
    By declanhalpin in forum MadCAM
    Last Post: 04-18-2013, 03:30 AM
  4. contoured path is faceted?
    By fjbart70 in forum Bridgeport / Hardinge Mills
    Last Post: 06-26-2011, 03:55 PM
  5. FACETED ELLIPSE
    By cncstephen in forum Mastercam
    Last Post: 06-15-2011, 10:23 AM
