588,208 active members*
4,036 visitors online*
Results 1 to 5 of 5
    Jun 2008
    113
    G43 being cancelled on G28
    The control is Fanuc 32.
    I am programming a four axis HMC pallet machine. Before rotary indexing, Z is moved to the reference position to avoid collision. The problem is, G28 G91 Z0 cancels G43. So does G30 and G53. This was never a problem with Okuma post processor. I will modify the post but only if absolutely necessary. I'd rather find out another solution for moving the machine to a safe position without cancelling tool length offset. Any suggestions?
    Thanks.
    Feb 2006
    1792
    Re: G43 being cancelled on G28
    Return from home position may automatically re-incorporate G43. May check.
    Such behavior are normally parameter-dependent.
    Jun 2008
    113
    Are you saying that there is a parameter to not cancel G43 on G28, or that there is another G-code that will reapply the previous G43 Hx after G28?
    15362
    Quote Originally Posted by myhäje View Post
    Check to see you don't have a G49 anywhere in your program this will cancel the G43 tool offset
    Mactec54
    Feb 2006
    1792
    Please check the possibility of length compensation automatically reinstated after return from home position. If so, there is no problem.
    I have only i-series manuals. The length-compensation chapter of Operator's Manual needs to be looked into.
  1. RFQ - Turned Steel w/ Drilled & Tapped Set Screws (Cancelled)
    By AuroraDrvr in forum Employment Opportunity
    Last Post: 04-14-2009, 07:12 AM
  2. Have you cancelled your Solsylva build?
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 01-21-2007, 02:49 AM
  3. Cancelled due to loss of enthusiasm.
    By widgitmaster in forum DIY CNC Router Table Machines
    Last Post: 11-08-2006, 02:50 PM
