587,375 active members*
3,647 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
    Mar 2011
    357
    LPT vs USB vs ETH what is better and why
    Looking for a discussion of what is better to use.
    Is the printer port on an old machine in any way better or worse than using a USB or ETH motion control board?
    Is buying a motion control board worth the money?
    As far as software is concerned I am leaning towards UCCNC but my still go the Mach3 route.
    Apr 2013
    1899
    Re: LPT vs USB vs ETH what is better and why
    Go for UCCNC and UC300ETH or UC400. That's the best of the two. Mach3 is simply too old and outdated regardless of the interface you use.
    35538
    UCCNC does not work with a parallel port.
    As stated above, either of the ethernet boards are the best choice. Don't bother with USB.
    May 2017
    31
    £3 BOB for me with parallel port, one of the hardest things was finding a pc with a PP, in the end I bought 2 PP PCI cards (1st one didn't work) to get a working PP for linuxcnc. My budget is always pushed so had to build the router in spurts as the paychecks came in so made more sense to me to get the AM882's and 70v PSU with cheap BOB than an expensive controller with cheaper drivers and crapper PSU. I would like to upgrade at some point but I don't see any hurry rather play with the router first for a couple of months and of course it's xmas in a few weeks.
    If you are the building stage getting a BOB is good even only for testing the motors/axis, etc before you buy a better board easy enough to swap across.
    I wanted to use Linuxcnc so my options are more limited although they're are many expensive hi end options available they are beyond the budget and aimed at servo machines I have a simple nema 23 steppers.
    If anyone can point me at a linuxcnc compatible controller in the £2-300 range I'd appreciate it.
    Jul 2003
    1754
    Depends on the budget - you can get an Ethernet mesa board that acts like 2 printer ports on steroids for $89 and is expandable. (with realtime communication)
    https://mesaus.com/index.php?route=p...&product_id=98
    Quote Originally Posted by Tutu View Post
    May 2017
    31
    Quote Originally Posted by samco View Post
    Nice one that's exactly what I was looking for! I heard of these controllers but couldn't remember what they were called.
    At moment I have 2 PP and 2 BOB's but I'm only using 1 BOB only got a simple 3 axis router and I have no Z axis switches so I don't have a use for extra inputs yet but that's the obvious upgrade route.
    I take it I still use my PP breakout boards with it?
    Mar 2011
    357
    is BOB (break Out Board) a generic term for the UCC200eth and the Smothstepper type boards or something else entirely?
    May 2017
    31
    Quote Originally Posted by tkms002 View Post
    https://www.ebay.co.uk/itm/5-axis-MA...gAAOSwq5lTq-Dx
    This is an example of a cheap LPT breakout board it literally is breaking out the pins from the parallel port into something you can work with. The relay is for turning on/off the spindle.
    35538
    Something else entirely.
    A breakout board plugs into the motion controller and provides you with terminals to connect your wiring to. Breakout boards range from very simple, terminal only boards for $10 or less, to full featured boards that add relays, speed controls, and other features, and can cost up to $200 or more.
    Feb 2008
    644
    Yes, you can use most parallel port BOBs with the 7I92
    May 2017
    31
    Quote Originally Posted by PCW_MESA View Post
    I just realised I could use my spare all in 1 pc which has a touchscreen if I have an Ethernet controller which would be cool
    35538
    If you are talking about UCCNC, you need the following:
    Motion controller - UC300ETH or UC400ETH
    Breakout board (or multiple breakout boards) which plugs into the motion controller.
    Stepper drives and stepper power supply. The stepper drive is wired to the breakout board.
    Jul 2003
    1754
    Sometimes the motion controller (I use this term loosely as with linuxcnc the external hardware isn't a motion controller) has an integrated 'BOB'.
    Example.
    https://mesaus.com/index.php?route=p...&product_id=66
    This has 5 axis step/dir, 48 isolated i/o, analog spindle speed control, diff/ttl encoder interface and expandable.
    So
    Code:
    Computer -> Ethernet cable -> mesa 7I76E -> stepper drives
                                             -> spindle drive
                                             <> i/o
                                             <-spindle encoder
                                             ->expantion
    35538
    But he's asking about a UCCNC setup.
    Jul 2003
    1754
    I thought he was asking in generic terms... I was just giving another example.
    Ok so now I am confused. What hardware is needed between the Ethernet cable and the stepper motors?
    Mar 2011
    357
    OK So lets say I have decided to go with UCCNC.
    I have a 4 year old laptop. Can I use this to run the machine?
    What would be a good reliable hardware set up that would include the possibility of adding a torch height control?
    Looking for a proven set up including what 4 axis stepper kit to get. I am building a 4x8 router with the possibility of adding a plasma cutter to it. The gantry will weigh
    about 40lbs all up.
    So, ethernet cable to UC300ETH, to ( ) to stepper drivers to the steppers.
    I know there are a million ways to do this but I want a reliable system that is PROVEN to work together.
    Thanks for any suggestions.
    Apr 2013
    1899
    Impossible to answer that with a definite yes or no. Personally I run my UCCNC and UC300ETH based CNC on two PCs, one laptop and one dektop, both are older than 4 years and both run just fine. But I am not in control of your PC, so I have no idea about how you have it installed, which performance it has, how able you are in managing it and so on.
    Mine is good and reliable, but I use mine for milling, so torch is not involved. Mine is using 2 pieces of 5$ BOBs and four DQ542MA drivers, NEMA23 steppers + VFD and 1.5kW air cooled spindle, DIY analogue unregulated PSU for the stepper drivers.
    about 40lbs all up.
    Nobody can give you a definite answer because only YOU know how reliable YOUR machine is is because it it depends on your own abilities of building it, so on you can prove that it works or not. Others have done the same, they have built reliable machines and can prove that THEIR machine works, but not yours.
    35538
    There are way too many variables involved for anyone to properly tell you what steppers and drives to buy, without knowing all the details of your machine, and your performance goals.
    Are you saying the gantry is 40lbs, including the spindle? That would be a pretty flimsy machine. How are you driving the gantry?
    If you want the best breakout board for the UC300ETH, it's the UB1 from CNC Room. That's what I'm using.
    I don't know anything about plasma, or it's requirements.
    Mar 2011
    357
    OK what variables are needed to make the necessary decisions?
    I haven't built anything yet. I have a section of 3x4x.125 steel tube I was going to use for the y axis. I am going to use the CNCrouterparts linear bearings and rack and pinion set up for the y and x axis and a
    lead screw set up for the z that is similar to how they build theirs.
    I don't have a spindle yet so I really don't know how much that weighs.
    Still learning.
    Mar 2011
    357
    I would be very interested in any comments there may be on my last post.
Page 1 of 2 12
