I would like to be able to probe a bore that is egged to find the average center of the bore. The issue is that I cant find a probing cycle that will allow more that 4 points. Is there any help out there?
WANNA GO FASTER
Do a one point probe cycle, load the touch into a variable
Do this for as many touches you want, loading each touch into a separate variable then calculate the average of the variables.
I dont see any way to take single hits with a vector cal probe.Much less stitch those points together into a circle. It would have to be vector calibrated to take hits in a non-orthagonal direction.
I would argue that the 4 hit bore boss cycle IS giving you the average/centroid of the bore.
you can run 3 point bore, store that position. run it again 180 out and average the positions. Still have to vector calibrate
Post an example of the code your orthagonal probing cycle uses and I should be able to help with this... what software is your probe running from easy set, mazatrol, etc etc?
I see 840D in your username.. the siemens controllers I have no experience with, but I believe they use a conversational user input that is translated to g-code type programming similar too how say the old okuma IGF worked??
hi, for probing more than 4 points inside a bore, or, for contact points at angular positions <> 0 90 180 270, it is required a probe ( and software ) that is sensitive to cosine directions, thus can detect if the contact surface is perpendicular ( or not ) in respect to feed direction / kindly
If the Probe was factory installed, the Inspection plus software is in the machine. The macros are as well, so you can give it the macro commands as needed.
I'd imagine you might be able to run the M165 probe bore cycle, store the results in a second bank of open macro locations, then G68 or rotate the machine coords 45 degrees and run a duplicate cycle.... likely then sort thru the 8 results for an out of tolerance condition?
