588,202 active members*
4,542 visitors online*
Results 1 to 16 of 16
    Feb 2007
    67
    Issue with macro variable #3002
    Good day folks,
    I've exhausted all my search options and found nothing that address my specific issue.
    I have a 35i milling control. I am trying to use the #3002 hour timer to extract cutting times. From what I've read, I reset #3002 to zero before the start of my cutting path. At the end, set another non-volatile variable to the value of #3002. I'm expecting this value to be expressed in some expected format. I don't actually know what I'm getting.
    At around the 15 minute mark after I've reset the #3002 variable to zero, the elapsed time (by setting another NV variable to #3002's value) is reading a value of .00099111111. I can't even imagine what this is telling me. I thought it was supposed to be expressed as hours in a decimal format...say 15 minutes would be .25. Obviously this isn't the case. I'm not a newby as far as macro programming, but this has me baffled.
    Can anybody fill me in on what I'm seeing and what to do with it?
    Many thanks!
    Feb 2006
    1792
    Re: Issue with macro variable #3002
    #3002 is a read/write variable.
    Its value is preserved even after a power cycle.
    It measure ON time of CYCLE START lamp in 1-hr increment.
    Feb 2013
    21
    Have you tried using something like this:
    #500=[#3002*60]
    Feb 2006
    1792
    It would give 60, 120, 180 etc.
    Feb 2013
    21
    sinha_nsit,
    No disrespect intended but we do this all the time. Is something different with the 35i control?
    Feb 2006
    1792
    I do not think it is control dependent. Same behaviour is expected.
    The manual says "1-hr increment". Without checking, I just assumed that fractional time is not stored.
    Thank you for useful information.
    So, for 15 minutes, #500 stores 15?
    Feb 2013
    21
    Quote Originally Posted by sinha_nsit View Post
    For 15 minutes #500=.25
    Feb 2006
    1792
    Quote Originally Posted by Hardym1 View Post
    It should be 0.25 WITHOUT multiplying by 60. Please check and confirm. I am relying on what is written in Fanuc manual. But, mistakes can be there.
    Feb 2013
    21
    There are 60 minutes in 1 hour which means that if you run your machine for 60 minutes then #500 would equal 1 (for 1hr), but anything less than 60 minutes is now equivalent to 1/3600 (the 3600 is the # of seconds in 1 hr.). So if you run your machine for 6 minutes #3002 will equal .0002777778 x 6 (.0016666668). You then have to multiply that by 60 to get the portion of the hour the machine was running. In this case #500 would equal .1 (.0016666668 x 60), if you run your machine for 15 minutes then #3002 equals .0002777778 x 15 (.004166667). Multiply that by 60 and #500 would equal .25 (.004166667 x 60).
    Feb 2006
    1792
    I have a doubt.
    When the time is in hour, and you multiply it by 60, it should be in minutes.
    How to explain 0.25 for 15 minutes?
    Feb 2007
    67
    .25 hour = 15min.
    Thank you all for your posts. I have decided to use a millisecond timer instead since it is giving me output that I expect.
    Obviously you may all continue this discussion if you believe it is productive.
    Feb 2006
    1792
    What you are saying is correct with regard to #3002.
    But, #500 is not same as #3002.
    You have defined #500 as #3000 x 60
    Feb 2013
    21
    Your right, #3002 is not the same as #500. #3002 is a system variable (you can not see this). #500 is the common variable where we store the data so we can see it.
    Feb 2006
    1792
    Because #500 is #3002 multiplied by 60, what you are saying about the value stored in #500 is not correct.
    Feb 2013
    21
    This is now becoming unproductive. I do this everyday on my machines as does every other machinist that works here, I don't just read it in a manual.
    Feb 2006
    1792
    Somehow I am not able to convey to you what I have in my mind.
    Never mind. Let us stop this unproductive discussion.
  1. Accessing Macro Variable from another macro
    By ex-egll in forum Mach Wizards, Macros, & Addons
    Last Post: 02-01-2014, 06:52 AM
  2. Macro b variable order
    By Diggitdude in forum Parametric Programing
    Last Post: 01-13-2014, 06:02 AM
  3. Macro Variable #500
    By DruMor in forum Haas Mills
    Last Post: 11-28-2013, 03:50 PM
  4. Macro/Variable Programing
    By chadr03 in forum WinCnc
    Last Post: 02-02-2011, 02:00 PM
  5. macro error 3002
    By Dinger89 in forum Fanuc
    Last Post: 01-21-2010, 12:31 AM
