587,177 active members*
3,304 visitors online*
Results 1 to 7 of 7
    Calibrating Renishaw probe
    We picked up a used 2004 VF6 a few months ago and I'm finally getting around to setting up the probe, the stylus was broken when i got it so I ordered a new one, I'm having trouble getting the probe to calibrate, and can't figure out where to go, it doesn't have a tool setter, just the spindle probe. When i find the center of a ring gauge and bring the probe down, go into VQC and choose the calibration template for inside a bore set the diameter and hit start, the probe turns on spins and beeps a few times and then goes up to Z0, it doesn't move in X or Y, there are no alarms and the error light is not on on the Renishaw control box in the cabinet. What am I doing wrong? Thanks for looking.
    Nov 2006
    490
    Re: Calibrating Renishaw probe
    The first thing I'd try is to re-load all the probe's o9000 programs and try again. The spindle probe calibration routine shouldn't move anywhere in Z.
    Oct 2015
    9
    First thing you need to do after installing a new stylus is to center it with a .0001" test indicator. This process can take anywhere from 15 minutes to a few hours depending on how bad out of center the tip is.
    Make sure your batteries are good. Testing with meter isn't very accurate as it will read good voltage right up until they crap out forever. When in doubt, replace batteries and write the date on them when you do.
    Ensure that you have Macro's enabled on your machine, the calibration cycle doesn't work properly without them.
    Then calibrate the work probe, in MDI -> Setup -> Work Probe Calibration. VQC is not recommended for calibration as it is possible that values will be written to the wrong place. Any size ring can be used as long as it is concentric and of known size.
    Feb 2012
    115
    If centering of the stylus to .0001 really is only so you can use it both directions. If you always face it the same direction, it isn't as critical.
    Oct 2015
    9
    Quote Originally Posted by erikfriesen View Post
    You must center your probe. If the probe isn't centered properly, it will not match up with the spindle and tool centers which leads to bad parts. Also, there is no guarantee that when you call up the probe it will have the exact same orientation every time.
    Nov 2006
    490
    That's not entirely true; the OMP calibration will measure and compensate for a small amount of runout. The measured XY runout is stored in variables #558-559.
    Regardless, personally I tell people it's a good idea to mechanically align the tip to get it fairly close, since it can't hurt.
    Oct 2010
    171
    jbranting,
    Does your machine have spindle orientation?
    The probe needs to be in a known position before you do anything (whether that is probing, calibrating, etc.).
    My SMM does *not* have spindle orientation (only orienting for tool change), but the Renishaw wizard who set it up wrote a small routine to somehow orient the spindle correctly for probing.
    PM
  1. Replies: 8
    Last Post: 01-11-2020, 11:39 PM
  2. Replies: 2
    Last Post: 12-19-2017, 04:23 PM
  3. Need Help -- Calibrating Renishaw MP12 in Mazatrol
    By pjr170 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-01-2009, 03:04 PM
