587,453 active members*
4,228 visitors online*
    May 2017
    58
    Y axis home issue
    After resolving a x axis issue i can jog normally on x and y. When calibrating machine calibrates z and x but fails to back off of the y limt and throws an encoder fault for y. Limit switch will register triggering on plus and minus portion of the switch. Machine ran fine untill x axis had issues. Now it cannot calibrate due to new fault.
    May 2017
    58
    Apperently it will calibrate fine if i invert the logic on the y axis. Is this in the limit switch or on the conector for the amp from the limit switch?
    Quote Originally Posted by Sandvet03 View Post
    Oct 2004
    188
    Re: Y axis home issue
    What machine do you have? If +y and -y are shown on the screen it is the limit switch, on most machine1995 and new are all that I am familiar with. sounds like it is hitting both the plungers at the same time.
    May 2017
    58
    97 hawk 5m. For some reason it only calibrates with the y axis coordinate system inverted in the controler logic.
    Cleaned and tore down/rebuilt the limit switch starting to think the inputs from the limit to the drive amp are flipped
    Quote Originally Posted by powerr View Post
  1. Replies: 2
    Last Post: 06-29-2018, 08:08 PM
  2. Positive home issue
    By brightprojects in forum Machines running Mach Software
    Last Post: 02-18-2018, 09:28 PM
  3. Mach3 - home switch issue
    By CitizenOfDreams in forum Mach Software (ArtSoft software)
    Last Post: 09-20-2016, 03:59 PM
  4. Mach3 Limit/Home issue with slaved axis
    By Dub_ in forum Machines running Mach Software
    Last Post: 11-29-2015, 06:16 PM
  5. excell vmc y home issue
    By bigbobr in forum Uncategorised MetalWorking Machines
    Last Post: 09-28-2011, 02:30 PM
