588,221 active members*
3,833 visitors online*
Thread: Spoon Feed?
Results 1 to 6 of 6
    Mar 2006
    54
    Spoon Feed?
    I have a Fadal 4525 VMC with a Fanuc 18i-MB5 conrtol. The control is conected to a server thru a LAN. Fadal failed to mention the low onboard memory and tells me spoon feeding from the server won't work. Has anyone come across this same problem? Is there a way around this?
    Apr 2007
    Run it off off a data card. You should have a slot on the control. I use this to tranfer my progams and run large 3d progams. It is kind of like using dnc.
    Mar 2006
    54
    It has the data card slot also.I was trying to find a way to spoon feed thru the server over the LAN. The server is in a differnt building where I use GIBBS to right the programs. I guess I'm just getting lazy and trying to save a few foot steps.
    Aug 2005
    249
    IMO, trickle feeding programs via a server or over a network is very risky. There is too much noise and cnc machines do not need much excuse to halt data input. Perhaps using a notebook computer would help.
    Jeff Lange
    Lightning Tool & Manufacturing, Inc.
    Jan 2006
    33
    Drip Feeding from the card on front works fine. I have the extended memory
    for the same control but still run into not having enough. This is one of the few weak points of Fanuc controls. If you have the Data Server also you should be able to drip feed from it , but it is the same as the mem card.
    Ken
    Mar 2006
    54
    Thanks for the Info. I am getting the data server installed.
  1. Feed Rates
    By rcheli in forum Benchtop Machines
    Last Post: 12-28-2005, 05:34 PM
  2. Feed & Speed Help
    By kaleem1 in forum MetalWork Discussion
    Last Post: 11-04-2004, 02:21 PM
  3. Feed ?
    By Ken_Shea in forum MetalWork Discussion
    Last Post: 11-01-2004, 01:37 AM
