587,999 active members*
2,660 visitors online*
Results 1 to 20 of 22
    Mar 2013
    344
    No Path Pilot for Rapid Turn?
    I finally got around to trying to do something useful with Rapid Turn. Well, I didn't get very far. Actually I got nowhere. It seems PathPilot supports the Duality but not the RT. Still, I took a look at Duality's conversational app in PP. It's a nightmare. For a simple facing operation it asked more questions than my wife does when I come home late.
    Ultimately, all I want to do is to face, drill, turn two o/s diameters knurl, chamfer, and part. Something easily accomplish on my 14x40, but since I need quite a few of the parts, the RT seemed appropriate. Had to take the family out to eat so had no time to try to manually write the code. That left me wondering will PP/RT even support standard lathe g-code?
    Nov 2012
    591
    Re: No Path Pilot for Rapid Turn?
    The page for "rapidturn upgrade from duality" says explicitly:
    "RapidTurn™ requires PathPilot"
    So ... there's probably some setting or configuration needed, but Rapid Turn should be controllable from the PathPilot.
    Maybe you checked an old version? Or maybe the duality/rapidturn are just the same module?
    Apr 2008
    19
    What version of PathPilot are you using? PathPilot has been set up for Rapidturn for quite awhile. I attached a screen capture of a older 2.0.x version, not sure if the picture will come through, but it should say RAPIDTURN in the lower right hand corner of the screen. If it doesn't, I suggest that you upgrade at least to V 1.9.13.
    https://www.tormach.com/support/soft...release-notes/
    Attachment 409036
    Mar 2013
    344
    Quote Originally Posted by Sir John View Post
    Attachment 409036
    Thanks, I'm using ver 1.7.2
    Apr 2008
    19
    That is a pretty old version. try updating to at least V 1.9.13 and see how it goes for you.
    Jul 2004
    1424
    Pathpilot version 1.7.2 (which you are using) was released on 15 April 2015.
    The RapidTurn product was released in June 2016, and a new version of pathpilot was released to support RapidTurn at that time.
    Like others have said, update RapidTurn!
    I would strongly suggest you go to the current version, which will require you to buy a USB stick from Tormach (version 2.0 and above installed a new Linux OS, and required an install USB stick for that).
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Mar 2009
    1863
    I’d like to try Rapid Turn, but it’s not compatible with my MACH III, and as long as my MACH III still works, why change.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Apr 2013
    1788
    Quote Originally Posted by Steve Seebold View Post
    Perhaps you should change because you would like to try Rapid Turn?
    Mar 2013
    344
    All's good now. i down loaded the last 1.9 version and RT is alive and well. I''m too much of a cheap skate to pay $100 for the 2.x version on a USB stick. And unless there is a compelling reason to do otherwise, like recognizing my pendant, it will never happen.
    Apr 2013
    1788
    Actually only $24.95 for 38249 - PathPilot v2.0 Upgrade
    Mar 2013
    344
    Why so many updates? Shouldn't they have it right by now?
  1. Tormach Rapid Turn / Path Pilot parting question/ bug??
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 08-30-2016, 06:08 AM
  2. Got my Path Pilot
    By BIG IGG in forum Tormach PathPilot™
    Last Post: 02-10-2016, 03:06 PM
  3. Path Pilot Thread
    By Steve Seebold in forum Tormach Personal CNC Mill
    Last Post: 01-26-2016, 04:37 PM
  4. --Unlocking Path Pilot--
    By Jim Anderson in forum Tormach PathPilot™
    Last Post: 09-19-2015, 04:32 PM
  5. Path Pilot - Rasberry Pi 2 b
    By tosatool1 in forum Tormach PathPilot™
    Last Post: 03-19-2015, 08:07 PM
