588,496 active members*
4,483 visitors online*
Results 1 to 20 of 22
    Mar 2018
    16
    Spindle not working
    My 110v 800w air cooled spindle will not spin. It's got less than 10hours of use. Is there a way I can bypass the VFD and power the spindle to prove that it's the spindle and not the VFD.?
    Apr 2004
    5760
    Re: Spindle not working
    I suppose you could borrow someone else's VFD, but no; you need an inverter to provide the 3-phase power the spindle actually runs on.
    Andrew Werby
    Website
    Mar 2018
    16
    Thanks, Kinda thought so. I was always going to upgrade to water cooled and I guess the time is now. Just hope it's the spindle. Unless there's a way to check out the VFD.
    Mar 2018
    16
    Quote Originally Posted by FGS View Post
    I did a continuity check and that was fine and eliminates the wires.
    Mar 2018
    16
    It's working. I reset the VFD PD013 = 8. Then reprogrammed the VFD. plugged it in and it works. The only explanation I can think of that there must have been a surge or something that screwed up the settings. It had been working for almost a year without incident.
    15362
    When you said you plugged it in, plugging and unplugging could cause this problem if that is how you are using it, VFD Drives don't like to be unplugged to disconnect the power, and should never be used this way
    Mactec54
    35538
    Does the VFD display appear to be working?
    Unplug the spindle, and check the resistance of the 3 wires to each other. You should get 3 identical readings.
    Sep 2006
    6463
    In other words, you power the spindle down to zero with the VFD and then it can be switched off?
    As the man, said it would not be practical to leave a VFD plugged in to a mains supply unattended for any length of time as the mains can drop out any time even for a brief instant and that is a switch off/unplugging by anyone's interpretation.
    Thanks to Mac for the tip......I'm sure not many people, if any, switch a VFD off at the power point while it is in the running position...…….I would think that if the motor was turning when the VFD was unplugged the back EMF would do some mischief to the VFD......would a set of diodes on the output lines cure that problem?
    What happens if, during a run cycle, a breaker trips or you get a complete loss of power etc...…...like they do frequently in South Africa.....total blackout for hours at a time...….I would think that in that case a UPS would be highly recommended.
    Down here in OZ we have an earth leakage device on the mains power board that detects a leakage to earth, or your body if you contact the main wiring etc, and will immediately switch the power off before you can get zapped to bits......it acts if it detects even a few milliamps of an earth leakage.
    Ian.
    15362
    Quote Originally Posted by handlewanker View Post
    Ian.
    Quality VFD Drives can handle those kind of problems, ( like Power Loss ) but the cheaper VFD Drive can not and most will fail when this happens
    This is what a EStop did to one spindle from 24,000
    Mactec54
    Sep 2006
    6463
    I was under the impression that the Estop button cut all power to the machine.....how can a spindle winding be burnt out with no power present......looks like a water pump failure.
    Ian.
    Sep 2005
    1740
    A lot of the Chinese drives are not built to a decent standard and will fail for just about any reason.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  1. Replies: 0
    Last Post: 11-30-2018, 09:54 AM
  2. Spindle Not Working
    By mussersail in forum Avid CNC
    Last Post: 03-18-2018, 12:51 PM
  3. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  4. Spindle not working on X3
    By EugeneJohn in forum Benchtop Machines
    Last Post: 03-29-2010, 03:33 PM
  5. Spindle not working on X3
    By EugeneJohn in forum Mach Mill
    Last Post: 03-24-2010, 09:13 PM
