588,525 active members*
5,948 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Bison chuck breakdown.............
Results 1 to 10 of 10
    Aug 2006
    71
    I picked up a nice used bison and I'm trying to get the back plate off to change out and would like crack it open to do a total clean up on it before using it.
    I've beat this thing with a rubber mallet till my arm is about to fall off and I can't it crack or get the back plate to move either.
    Yes, I have removed all the visible bolts on both sides and can't get it budge.
    Any clues or advice would be greatly appreciated.
    Jun 2015
    4171
    Re: Bison chuck breakdown.............
    hi leave it imersed in petrol over night, use degreasing spray, thus take some time to clean it; sometimes i put it on the vmc table, and use the showers for a while
    be sure that you are hammering it right
    use also bronze / aluminium rods
    if parts inside the chuck are not in good condition, maybe you can order them separately, so to replace only what needs to be replaced
    when i clean/disassemble the chuck, i ask for help at guys with gentle hands : grinding guys, etc
    " keep your tongue straight inside your mouth " is the best advice that i have been told so far / kindly
    Aug 2006
    71
    Quote Originally Posted by deadlykitten View Post
    Appreciate your insight. I searched youtube up and down and couldn't find you guy cracking a chuck. Usually find any and everything on there.
    Jun 2015
    4171
    so far i have messed with cnc lathe chucks with this construction :
    https://www.youtube.com/watch?v=9syWRN-RL9E
    Aug 2006
    71
    Thanks for the heads up....I was looking for someone breaking a bison and didn't see this one.
    I'll have a look...maybe give me a pointer.
    Dec 2013
    5722
    On the back of the chuck there are normally tapped holes in the body. These are used to ''jack'' the back of the chuck off of the main body.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2006
    71
    Thanks Jim...
    Ok...now I feel stupid.
    I forgot to loosen the set-Tru adjustment screws to remove the back plate. Once I did that it basically fell off!
    Heading to get some metric bolts to jack the main body into halves.
    Appreciate all the help.
    Aug 2006
    71
    Thanks to all your help I'm half way home. :cheers: Just need to remember how it all goes back together now! :idea:
    Not bad for a 400$ find.....not one metal shaving inside....all old grease and wood dust/chips.
    Absolute minimal wear on the scroll and jaws. I can barely find anywhere it's rubbed.
    A little staining on the back side but a quick stoning shows up no high spots.
    Overall happy as a pig in slop. Just need to get the correct back plate now and I'll be able mount this used gem and check her out to see if she plays nice.
    Jun 2015
    4171
    hi jim, good tip, after reading your reply, i was going to say that those tapped holes are existing or not, depending if the chuck is a direct-mount type or not
    i believed that it was about a hydraulic chuck
    Quote Originally Posted by cnc Rookie View Post
    nice job
    the satelites are generally ok, look carefully over the archimedean spiral, if it was an abuse, it leaves a mark on it / kindly
    Aug 2006
    71
    Waiting on a new back plate. This baby is as snug and smooth as it was when it left Poland!
  1. bison chuck mounting bolt circle?
    By kesparate in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-06-2018, 07:20 PM
  2. Bison Collet Chuck to A2-6 Spindle
    By Honeywell Joe in forum CNC Tooling
    Last Post: 11-11-2011, 12:18 PM
  3. Need 3D Bison Chuck model!
    By montie in forum Uncategorised CAM Discussion
    Last Post: 02-19-2011, 11:32 AM
  4. Lathe chuck from Bison
    By basketballfreak in forum Chucking and Measuring
    Last Post: 12-10-2008, 02:33 PM
  5. Bison vs. Buck 6-jaw 6" chuck
    By mackeym in forum Uncategorised MetalWorking Machines
    Last Post: 01-02-2008, 09:37 PM
