588,468 active members*
4,890 visitors online*
Results 1 to 2 of 2
    Jun 2013
    3
    Slave Axis Homing
    Using ESS & Mach3. My Slave axis works fine, except when doing ref all home. I hit ref all, the Y axis moves toward the proximity sensor as normal, but the slave axis moves a short distance then stops causing my gantry to rack. Setting the both Y/Slave axis to home together works without any faults.
    I have researched this quite a bit today, kind of at my wits end. Anyone experienced this and resolved it?
    Mar 2013
    140
    Re: Slave Axis Homing
    go to:
    Config>general config
    • uncheck A-axis in angular
    • check home Slave with master axis
    Config>Homing/Limits
    • Make sure your settings for A (the slave axis) are the same for the motor to which it is slaved (The Y in your case). You might have to check "reversed" depending on how your machine is configured.
  1. How to configure for homing master and slave axis
    By justCNCit in forum Mach Software (ArtSoft software)
    Last Post: 07-11-2017, 06:22 PM
  2. Homing X-Axis A-Slave
    By kaetamer in forum Avid CNC
    Last Post: 10-06-2015, 10:05 PM
  3. Homing Slave axis
    By litleboy in forum Mach Software (ArtSoft software)
    Last Post: 05-20-2014, 07:19 PM
  4. need help with homing slave A axis in mach 1.83
    By ozon in forum Canadian Club House
    Last Post: 07-02-2012, 10:19 PM
  5. Dual Y Axis Slave A Axis Homing Problems
    By guy2b1 in forum Calibration / Measurement
    Last Post: 03-03-2012, 11:06 PM
