587,203 active members*
3,354 visitors online*
Results 1 to 15 of 15
    Jul 2018
    87
    Profiles off center on Cnc plasma
    Hi All on my home made Cnc plasma I have a part with multiple holes and they are not in the correct places ..... what could be the problem? .... it’s like it shifted to the side, my steps per is correct.. I’m using mach3 and sheetcam, what’s strange is when I have this specific part cut it causes this problem, I was told I am loosing steps on nema 23 stepper motors or emi , but emi only effects the system before the torch fires and if I’m loosing steps how is this happening? ... iv attachet pix of the drawing and part, if you look closely it looks like the center geometry has shifted to the right.
    Thanx
    Bradley
    Oct 2013
    7
    What happens if you re-run the program over the same spot? Does the pattern shift each time, or follow the same path?
    Jul 2018
    87
    Re: Profiles off center on Cnc plasma
    When I do a dry run it’s spot on
    Sep 2011
    102
    I had a similar problem several years ago after the motherboard on my computer was replaced. As long as the torch was off the pattern was correct. As soon as I fired up the torch the table would lose position at various times. I went back to the manufacturer and asked for their advice on which motherboard I should be using. They sent me a different motherboard and the problem immediately went away. Some computer systems and components have trouble with the electrical noise that a plasma cutter puts off.
    Jul 2018
    87
    Hi plasmamett, I’m using a very old mother board and running Windows xp ... are u say I should use a later mother board?.... what mother board are u using?
    Sep 2011
    102
    The replacement motherboard that WinCNC sent me is made by ASRock. I don't recall the exact model. I am using Windows 7 on this particular computer. WinCNC indicated that ASRock motherboards are more tolerant to the electrical noise issues.
    Jul 2018
    87
    Is this the mother board you are referring to?
    https://www.makro.co.za/makstorefron...iABEgIaKPD_BwE
    Sep 2011
    102
    That is the correct brand but I'm not sure which model I have. It is going to be slightly different for your computer because you are running Windows XP. I'm at home right now and my plasma table is at work. I check on Monday and see which model I have.
    Jul 2018
    87
    Thanx a mill plasma
    Jul 2018
    87
    Hi plasmamatt just a reminder to have a look at the model of your asrock motherboard and let me knw
    Bradley
    Sep 2011
    102
    Sorry Bradley,
    I forgot all about it. I will make a note to check on this tomorrow.
    Jul 2018
    87
    No problem thanks
    Jul 2018
    87
    Hi plasmamatt, have u checked the model number of that asrock motherboard yet?
    Sep 2011
    102
    Hi Bradley, It's an ASRock B75M-GL R2.0. If this one isn't compatible with your computer I'm sure ASRock makes one that is.
    Jul 2018
    87
    Thanx a lot plasmamatt I’ll look into it
  1. Replies: 0
    Last Post: 08-10-2016, 09:28 PM
  2. Replies: 0
    Last Post: 10-08-2015, 04:14 AM
  3. Replies: 0
    Last Post: 09-19-2015, 07:13 AM
  4. Plate Marking and Center Punch options for CNC Plasma
    By Chestrockwell in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 08-23-2010, 02:51 PM
  5. plasma profiles
    By trevorhinze in forum Waterjet General Topics
    Last Post: 01-24-2006, 06:14 PM
