587,126 active members*
2,743 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Tips for straighter bores
Page 1 of 2 12
Results 1 to 20 of 30
    Oct 2017
    11
    What do you guys do when you are milling a tight tolerance hole with an endmill and can feel a taper towards the bottom. Assume it's a new endmill that's interpolating (ramping down) down the hole. I've heard everything from speed up rpm, to slow down rpm to slow the feed down.
    On a cnc machine, using gauge pins to check the hole.
    Dec 2013
    5714
    Re: Tips for straighter bores
    Second finish pass?
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2006
    6463
    Use a boring head set to size for the final pass.
    Ian.
    Jun 2015
    4156
    hi john rough until depth=h using a tool with normal chamfer, then finish until depth=h-0.03eq using a tool with smaller chamfer; for this to work, you need to measure both tools at same moment, because tool measuring senzor results values changes during a day, mostly because of termics
    depending on setup, you may consider prefinishing with another tool, so to be sure that the finish tool is always cutting in constant ae; like this, using a 3 tools combo, you may push the roughing tool for longer
    kindly
    Aug 2015
    36
    Just as Ian said, use a boring head to ensure cylindricity. If is a single part or a small batch I´d rather use a holtest micrometer to measure the bore.
    Greeting
    Ari
    Quote Originally Posted by handlewanker View Post
    Ian.
    Jun 2015
    4156
    hello, about reaming / cilindricity, etc, this is a pretty common thing; truth is that is much easier and reliable only to drill, while reaming may take longer
    is ok to rough, is ok to finish, but is less productive to debur or ream ... so there are operations that are more productive than others, and a cnc which runs non-productive operations is less-profitable; this does not mean that it is not profitable
    from this consideration, some shops avoid reaming operations on the cnc's; simply, because it is not productive, at least on small batches
    so, is about some shades of gray / how do you believe that is organised such a shop that does not ream on the cnc ? kindly
    Sep 2006
    6463
    Using gauge pin to check the hole????…..did you know that a 20.00 mm diam pin.....whatever...... is a press fit in a 20.00 mm hole?
    I assume the gauge pin is not a regular plug gauge with "go" and "no go" end sizes.
    Ian.
    Jun 2015
    4156
    hello handlewanker
    reading this, i remembered the dimensions translations, caused by the measuring method : for example, if a part has to be delivered with a bore dia20+0.03, then the actual size of the "good" part will be different, depending if it is measured with :
    ... an into or cmm ( this measuring method may deliver the smallest bore )
    ... an internal micrometer
    ... gauges ( this measuring method may deliver the biggest bore )
    in other words, if inside a shop is aplied a measuring method which is different then the method which is apllied at the client, there is a big chance that the client will reject "good parts", or accept "bad parts"
    this dimension shift problem is very accentuated when tolerances get smaller, and measuring method is not discused
    each measuring method, in order to validate a part as being "good", requires a different range for the bore tolerance and cilindricity
    a few years ago, i was in the situation to explain why 15um got shifted; lucky for me, the client understood, and the discussion was short, otherwise it could end in a messy situation
    you mean those sets, for example, if you have to deliver 20+0.03, then is ok to have gauges 19.95 19.96 19.97 19.98 19.99 20.00 20.01 20.02 20.03 20.04 20.05 ? each one ±3um kindly
    Sep 2006
    6463
    No....you need to have a plug gauge that has been made and calibrated by a company that makes gauges to be such a size that it will indicate the hole size required by the go and no go method......the customer MUST also use the same plug gauge to check the hole and it will be the same size as the one you are using.....there are no ifs and buts for that.
    You can gauge a hole with a telescopic gauge or an inside micrometer etc and it is the fit of those gauges and the skill of the person using them that determines the hole size.
    It can be said that no two people can measure a part with a micrometer and get the same results mainly due to one or the other using more or less pressure when applying the micrometer….whatever.
    A go and no go plug gauge MUST enter the bore with the go side and MUST NOT enter the bore with the no go side.....that is the only way to give a customer the results that his drawing tolerance states.
    It is also a fact that the plug gauge is made specifically for the size indicated by the customer's drawing tolerance.
    You cannot just stick a gauge pin in a hole and think it's OK......gauge pins are also made to a tolerance which is a one size only.
    You cannot make a plug gauge to check your work for a customer unless you have accreditation as a gauge maker.
    The fact that plug gauges are expensive and must be made to measure means many people forgo their use and rely on measuring their work piece with conventional measuring equipment.
    With batch work the cost of a plug gauge is ALWAYS costed to the customer and it is your guarantee of integrity.
    For example, where would you get a plug gauge to measure a 20mm bore that had a tolerance of plus .02mm and minus .04 mm.....those sizes are pretty slack and you could easily supply a part by measuring with an inside mike or a telescopic gauge alone......if your parts are on top limit they may be over size if you measure wrong......a plug gauge does not lie.
    If you are making many parts to a drawing then a plug gauge is a must have item.
    Ian.
    Jun 2015
    4156
    hi handlewanker, nice infos there / in some cases, i craft gauges, or even simple measuring fixtures
    however, so far, i had encountered setups that required extra-length of the go-gauge : in some situations, i have used go gauges 3d - 10d, and even combined go-gauges, like one that is 6d+6d, designed to check if 2 holes are cilindrical and coaxial
    there are parts that a cmm can not even touch, or, even if it does, it requires too much time to run the inspection, and results are questionable; i am not saying that a cmm is not ok, but in most situations, i preffer to have the measuring instruments near the machine ... this requires a few things, like clean hands, clean machine cabinet, no temperatue fluctuation, etc
    to eliminate doubts, a go nogo gauge, depending on dimensions, should have some friends :
    ... go nogo, for the go side ( go go, and nogo go )
    ... go nogo, for the nogo side ( go nogo, and nogo nogo )
    ... and, of course, these :
    ...... go go go + nogo go go , go nogo go + nogo nogo go
    ...... go go nogo + nogo go nogo , go nogo nogo + nogo nogo nogo
    is not common to use so many gauges, unless there is mass-production
    ... "main gauge" is crafted within tolerance T
    ... "calibration gauges", to verify the "main gauge", are T/3
    ... "factory gauges", to verify the "calibration gauge", are T/4 .. T/5, depends
    and, there is the frequency of usage :
    ... "main gauge" : every part, every 10parts, or daily
    ... "calibration gauges" : once at 4 hours, daily, weekly
    ... "factory gauges" : weekly, montly, yearly
    and there are the documents :
    ... "main gauge" results are not recorded, or maybe is used an "inspection template"
    ... "calibration gauge" results are not recorded, or maybe is used an "passport"
    ... "factory gauge" results are always written insisde the "passport"
    and the real location :
    ... main gauge - i preffer as near the machine as possible
    ... calibration & factory - a bit far away, in a less hazard place, like a peripheral room, under the sink, etc
    in other words :
    ... in most cases, is enough to buy a go nogo gauge + calibration certificate
    ... for long term setups, is ok to buy/have also the "calibration, and maybe the factory gauge" + passport
    is not a must to buy the "calibration/factory gauges", as long as there is a method implemented in order to check the dimensions of the "normal gauge"; but, if this method does not exist, and someone forces a gauge, thus uses too much force on it ( or gauge life is near end ), then :
    ... acceptable tolerance field gets reduced ( this is the nice case, as long as the process is still stable within the new-reduced tolerance )
    ... tolerance gets shifted, or even out of initial specs ( at this point, derogation documents kick in, tring to save as many parts as possible; if a part is out of the derogation, is trashed; derogation, depending, may allow the tolerances to shift with 5-20% )
    again, depends ... kindly
    Sep 2006
    6463
    No matter what you are using, a new gauge or a well used one, as long as the calibration certificate is current then the part is what the gauge says it is.....that is beyond question...….if your customer's gauges are not currently calibrated they have no valid reason to fail or reject your production...…..a current calibration certificate is holy writ.
    Ian.
    Jun 2015
    4156
    yup ... on some setups, is easier when the client gives you the crafting steps + control; something like : "here, take this, just replicate" - i love those ones
    about certificates, papers, etc ... some persons always check a gauge the 1st time they put their hand on it, regardless of that gauge being new or old; is a minihabit, like checking the caliper, micrometer, etc / kindly
    Sep 2006
    6463
    Well, I can't agree with you on that......a gauge is a set piece and it only checks the dimension that it is made for during the calibrated period of time.
    Gauges are calibrated periodically by a gauge maker who is accredited to do such work.....an ordinary person at the machine CANNOT check a gauge...…..and for that matter a micrometer or a vernier caliper or even a digital caliper.
    Plug gauges CANNOT and SHOULD NOT be checked against a set of slip gauges as the slip gauges need to be calibrated too.
    Did you know that a micrometer normally comes with a setting piece, but that only checks the maximum size range of that micrometer size and cannot check it's screw thread from zero to the big size end......they do wear and must be calibrated periodically etc etc
    BTW....if a customer doesn't give you specific sizes to make a part for with the tolerances clearly marked you may as well use a tape measure.....LOL.
    Ian.
    Jun 2015
    4156
    "plug gauges" are checked with "caliber gauges"
    "caliber gauges" are checked with "factory gauges"
    not everybody, but few can ...
    most operators have normal gauges
    few of them, the shift master and the control room has acces to calibration gauges
    control room has also factory gauges
    and also, there are other things, in other points; is not everything in one place, at one person; kind of a cross-reference
    maybe there are ( 10+ 20+ ... 50+ ) plug gauges, and 5 calibration + factory gauges
    maybe few persons are empoyed only for managing gauges & passports
    that is reverse enginering just saying / kindly
    Sep 2006
    6463
    I still disagree with you...…....end of topic.
    Ian.
    Jun 2015
    4156
    look handlewanker, you are right, is not ok to check with another gauge, is not common behaviour
    also, future perspective, is hard, when it comes to find good workers
    there are still places with a high level of experimented people; some places still have 1:1departments, other are 1:3 or 1:5; such things are pretty high, but i don't know for long
    average is below 1:10, or 1:30, and this is an average from 30 yrs ago
    what i had been talking about is not common, since shops tend to be sporadic, but there are still places that are centralized
    ok, let's say that you have hundreds of gauges at hundreds of people ... how do you check them ?
    1943
    Who cares!! The OP never even mentioned the tolerance of the bore he is working on. He only said that he is using gauge pins to check the hole and could tell the interpolated bore was tapered. A gauge pin may be just fine depending on the tolerance requirements. He simply asked how to take care of the taper.
    Aug 2004
    782
    This time I disagree with most posts.
    We did not get original posters d/l tolerances .. which are what it is all about.
    And size, depth, speed, qty goals.
    A reamer will deliver a hole about 0.01 mm in size, or a bit better, and mostly follow the bore while improving it a bit in straightness.
    Carbide reamers will make the hole straighter, and double-reaming will make the hole straighter and more uniform.
    Typical holes made with boring heads or modern vmc machines will have 0.01-0.02 mm tir/taper, to 0.04 mm (weak) bore sizes and straightnesses in the normal 1-3-4 d/l ratios.
    Sep 2006
    6463
    LOL....a veritable storm in a tea cup...…...the problem I highlighted arose form the ongoing conversation/post.....whatever...…..and concerned the aspect of a customer supplier relationship when it comes to producing work to a customer's toleranced drawing., so I suppose it doesn't matter if the hole is not to the tolerance as long as it's parallel.
    As long as the gauge pin, no matter what size it is, goes into the hole it will as you say tell you if the hole is tight at the bottom…….I can't imagine what you would make of it if the hole was tight at the top and oversize at the bottom.
    Ian.
    Jun 2015
    4156
    hello, yup, i started it i just remembered that a while ago, there was a calibration loss near the limit tolerance ... whatever, like you said, agreing with the client on control method helps
    i don't understand this
    sometimes this happens ... for example part is controlled inside the machine and is ok, but after it is taken out, sometimes it happens to be oversized at the bottom
    most common cause, is that the fixture puts too much pressure on the part, & the part changes shape
    a quick way to check it, is to leave the gauge inside the part, and take the part out : if the gauge does not slip as easy/hard as when the part was inside, or, if the gauge is blocked, than few adjustemnts are made
    this is "fluaj", i don't know the english word, rigid material that leaks slowly; unpleasant situation is when this phenomen has effect spread across a time period greater than fewhours-1-2 days
    to fix this, it may be enough to program a taper, or to reduce fixture forces, stabilize internal part tension through prior heat-treatments, etc / kindly
Page 1 of 2 12
  1. Manufacturing of ejector bores
    By Jens1000 in forum Drilling
    Last Post: 10-07-2009, 05:02 PM
  2. Sloping bores
    By ideefix in forum HEIDENHAIN -> GENERIC
    Last Post: 03-24-2009, 07:11 PM
  3. anybody compare HT finecut tips to TD 1Torch tips for dross?
    By Knut in forum Waterjet General Topics
    Last Post: 09-29-2006, 07:17 PM
  4. bearing bores
    By eschless in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2004, 12:03 AM
