587,999 active members*
1,865 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Double Arm Vertical alignment issue (Okuma Howa Millac 3VA)
    Aug 2010
    57
    Hi all,
    I had a small crash earlier today. Nothing seems too wrong except the arm is now too low for the pot in the carousel. I've included a picture to show you what I mean. Is there a way to adjust the arm up and down? I only want to have to figure it out the hard way if I absolutely have to.
    Jun 2015
    4164
    Re: Double Arm Vertical alignment issue (Okuma Howa Millac 3VA)
    hy, may be a friction couple related stuff, and at least z travel soft limits had been moved. I would check the soft limits and adjust; with a bit of luck, home 1 = tool change position, will get back to normal.
    if your limits are ok, then check the management data card for the z of the tool change position; maybe a program changed your home 1, but i am not sure if this is possible from code / kindly
    ps : i have no clue if what i said is ok 4 your cnc; i don't have experience with your machine type
    Aug 2010
    57
    What you're looking at is the arm at the toolpot in the carousel not the spindle, sorry. I didn't make that clear. The soft Z did move, but since the toolpot is off but that much I don't want to adjust the the grid shift until I get this part fixed.
    Aug 2010
    57
    And the issue has been found. The crash actually did damage something - the cam roller bearing that actuates the internal atc arm that moves the sleeve up and down.
    Unfortunately I didn't find this BEFORE removing the ATC arm, which means I now have to figure out how to align it.
    Ugh.
  1. Replies: 0
    Last Post: 05-17-2019, 07:55 PM
  2. Replies: 0
    Last Post: 09-12-2016, 05:56 PM
  3. Okuma & Howa Millac feed issue
    By gainst in forum Okuma
    Last Post: 01-23-2016, 10:34 PM
  4. Replies: 1
    Last Post: 10-14-2014, 05:49 AM
  5. Okuma & Howa Millac 5V tool changer issue
    By cheech669 in forum Okuma
    Last Post: 05-29-2014, 03:22 PM
