603,365 active members*
3,786 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD manual for MK100-2S2.2G-DK
Results 1 to 10 of 10
    May 2019
    Does anyone have the manual for VFD manual for MK100-2S2.2G-DK
    Have attached pic of the manufacturer plate
    Sep 2005
    1740
    Re: VFD manual for MK100-2S2.2G-DK
    Quote Originally Posted by Ktmben View Post
    No picture and why do you folks by these drives without documentation?? Asking your Chinese vender would be the first place I would try.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    15362
    So you have a CNC Control Panel with an open board VFD Drive there is a thread for these control boxes under 6040 I have some of there manuals but may not have your one you will need more information and take some photos of what you have inside the cabinet / box
    Mactec54
    Here is the manual you wanted.
    https://1drv.ms/b/s!AlWEvfzVs336oREF9zNq6qcxH5kF
    Jun 2025
    Quote Originally Posted by Crossfixer View Post
    Hi. I realise this was sometime ago but do still have the manual for the VFD.
    The link does not work.
    Cheers
    This saved the day for me cheers for the manual. Which setting if to allow Mach 3 to control the spindle speed?
    Apr 2020
    3
    Quote Originally Posted by Abersmith View Post
    Did you ever figure this out? I have a machine with the same VFD and I can't seem to get mach3 to control the spindle.
    Hello,
    I have a CNC6040Z S80 with a MK100-2S2.2G-DK in the black box.
    In the manual there is no info about RS485 / Modbus protocol...
    I have modified:
    P0-02 to 2 for communication command channel
    P0-03 to 9 for communication command for frequency control
    Modbus rtu request:
    with 01 06 20 00 00 01 I can RUN
    with 01 06 20 00 00 05 I can STOP
    But
    with 01 06 20 01 0F A0 i can't modify frequency.
    Did I miss something ?
    or Have you modbus documentation
    thanks a lot
    Laurent
    excuse my english i'm french
    i have a question for the frequency inverter MK100-2S1.5G-DK. I want to start my Spindle via CNC Software. My CNC6040 is from the Vendor "SXCNC".
    Has anyone ever wired the frequency inverter to the mainboard JP-3163B?
    Can you have a look to my Post here i worte all in details about my question?
    https://www.cnczone.com/forums/chine...ml#post2402392
    Regards Raini
    Hi a buy an chinazone CNC 3040Z-DQ 4-axis Router 800W Engraving Mach 3 USB Cutting Engraver Machine on ebay a while ago and havent been able to do anyting with it until now so a have done everything clear to start up the machine and try it out and check if stepper motors and spindel runs as it shud do, and a so far a have get the stepper motors to run ,but not the spindel motor?
    a have been looking all over to find help how to setup my VFD so the spindel start runing.
    a did not find any macth on the VFD controler panel anywhere a have looked so a desided to open it up and se innside to find out wicth VFD it had and find out that it is an MK100-2S1.5G-DK so there was an other question poping up??this is an VFD to 1.5kW spindel motor and the spindel a got is an 800W spindel motor eehh ok???
    Is that a problem??or can it be fixed changeing the parameters on the VFD to fit the 800w spindel??
    my software is Mach3 running on windows10,there is an mainboard MKS4-V in the controller box.
    so can anyone her help me how to setup this VFD to getting the 800w spindel start running on mach3? how this is done step by step with the VDF?
    And how to setup the end limit switches to functions proporly?
    A have been very happy to get some help getting this machine up and running
    thx dontworry21
  1. Replies: 0
    Last Post: 08-06-2018, 05:45 AM
  2. Replies: 0
    Last Post: 03-18-2016, 10:55 PM
  3. For Sale Complete Maho MH 600E Manual, + Philips 432 Programming Manual
    By HKgunslinger in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-08-2012, 08:09 AM
  4. Mecof CS100 manual & Zayer KM 8000 manual
    By australia in forum Uncategorised MetalWorking Machines
    Last Post: 02-25-2011, 11:59 AM
  5. Replies: 0
    Last Post: 06-17-2010, 12:59 PM
