587,098 active members*
5,610 visitors online*
Results 1 to 3 of 3
    Home/Limit Switch Guidance
    D&M 5 Lathe Acorn CNC retrofit, only replacing the controller and adding DC isolation for the spindle drive.
    Have everything about 75% wired up and just realized that there are no home/limit switches on the machine. Better yet I don't know the first thing about what kinds and where to place them.
    Looking for guidance on what would be the appropriate switched to buy, mechanical or proximity?
    Also where they should be mounted, I would assume they will be at the X+ and Z+ limits but how will this play with the tail stock.
    Any help you can offer or examples from your own projects would be greatly appreciated!
    -Joey
    Attached Thumbnails Attached Thumbnails 20190916_183858.jpg   20190916_183903.jpg   20190916_183908.jpg
    Mar 2008
    1762
    Re: Home/Limit Switch Guidance
    This may give you a few ideas: https://www.youtube.com/watch?v=NvlBFmM2yos
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Thanks islaww!
    Still a little fuzzy on how have a tail stock sensing switch works with the a Z axis switch and software.
    Is the tail stock switch being used as a limit switch to prevent collision? and the Z axis switch being used as home?
  1. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
  2. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 06:25 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
