588,209 active members*
4,282 visitors online*
IndustryArena Forum > CAM Software > Mastercam > help with pocketing on MCX
Results 1 to 10 of 10
    May 2007
    29
    Hi, i need some help with pocketing for this design. Im using mastercamx and i am having a lot of problems trying to pocket it. The stock is 8mm, the words are 6 mm tall, the circle in the middle is 4mm tall, and the base is 2mm.
    I am always getting the error of the chain being open even after i tried to offset the lines and selecting them in a closed loop.
    Anybody can give me some help?
    here is the attached file.
    Attached Files Attached Files
    Mar 2005
    461
    I am sure it is possible to figure out with 2-d contour but it would be easier to just use surface rough pocket.
    If you prefer to continue with the 2-d pocket routine maybe you could post your .mcx file with the problematic geometry and somebody here can explain where you are going wrong. It is always easier to explain a problem if you can actually see the error instead of just looking at a parasolid and guessing what the problem could be.
    May 2007
    29
    May i know how do i access the surface rough pocket tool? Is it still under the pocket tool or under face?
    May 2007
    29
    Ok, this is what i tried. I've attached the picture below:
    After specifying my mill and stock, i offset the entire design to 4mm and 6mm, this way it will give me the paths for all the different layers. After that i went on to select the pocket toolpath.
    - wire frame
    - C-plane
    - Chain
    - tried select the contour labeled A, but i get an error saying that the boundary is not closed, pls select open pockets or close chain.
    Can anybody explain why is it not a closed boundary? Or is there a better method of doing this?
    Mar 2005
    461
    Here is the surface rough toolpath.
    It's hard to explain why a chain is not closed without seeing it. There is probably a tiny gap in it.
    How did you create the chains ?
    May 2007
    29
    Hey thanks! I'll check it out.
    I create using pocket toolpath, C-plane, wire diagram.
    I manage to create some proper pocketing paths, but the next problem which i cannot solve is that one of my letterings is always being pocket away. See attached picture labelled B.
    Is there a way i can exclude that contour? I mean there must be a way, but how?
    Mar 2005
    461
    That letter must not have a closed chain. If you add a closed chain to the toolpath, the toolpath should respect it.
    May 2007
    29
    Thanks, i manage to solve it today after discovering the pocketing islanding facing function.
    Jul 2003
    263
    are you 100% sure you do not have double lines?
    If you can ENVISION it I can make it
  1. Pocketing in V9 help
    By Joe Rodney in forum Mastercam
    Last Post: 02-26-2007, 06:57 PM
  2. pocketing
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 06-06-2006, 03:04 PM
  3. Pocketing
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 05-12-2006, 02:44 AM
  4. Pocketing
    By dneisler in forum BobCad-Cam
    Last Post: 12-19-2005, 05:57 AM
  5. Pocketing
    By Mortek in forum OneCNC
    Last Post: 04-08-2003, 10:08 PM
