I don't mean to be a smart a** but this certainly has me confused,
The first place I'm messed up at is " My guess is around 0.005mm (0.0001")" ( I get 0.0002").
The second place is "a 1024x4 encoder will give his machine in the X & Y a resolution of .00124"/ . 031496mm" ( I get 10mm = .3937" per rev/4096 counts = .000096" (.002mm).
The third spot is "Don't go 4/1 that will put you back to where you were with the 500cpr encoders". Isn't the smaller pulley on the motor? If so doubling the ratio would double the resolution (if the encoders are on the motors).
Have I got something backwards here? Or maybe its just a late night math mistake.
Servo motors always prefer to have their encoders mounted directly to the motor shaft. Higher count encoders are easier to tune and run smoother (faster feedback to the servo loop). You get very little gain above 2000 lines (8000 counts) as the motor has a hard time responding to increments this small. 500 lines (2000 counts/rev) at the motor is as about as low as you would normally want to go to get a stable servo loop.
System resolution and accuracy are two totally different things. Servos are always in error when running at any kind of speed. I design for +/- 10 counts to my desired accuracy.
Bob
Bob
You can always spot the pioneers -- They're the ones with the arrows in their backs.
