587,614 active members*
3,631 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > 1998 Haas vf3 Renishaw Probe and TS setup help.
Results 1 to 2 of 2
    May 2013
    I have a late model 1998 haas vf3. I installed a MP8 probe and MI12 interface and a wired TS27r. I was given the easy set macro list 40120737.0C with VQC added. I do not have VQC graphic display as I believe my machine software is too old. Everything is working mostly. However the probe sets work offset G54 in the negative on the DRO then its balanced out on the offsets page. It works but doesn't say "0" on DRO readout when set. not sure if thats normal or a big problem.
    also I would like a quick code call for outside features xyz. I have a call for inside pocket that works good and the calibration for outside worked but no p9023 a... easy call for it on my list. I assume I could link single feature calls together wit Z moves in between to accomplish this all together ?
    Next issue. is The TS works only in single set manual option. I calibrated it For Z touch off but I can not run the radius calibration with out errors. (505 value stack error) anytime I edit any # in a macro (as pre the manual says to do) I get that error. if I run it as is the machine want to move all the way to the opposite side of X on the table away from the setter. then it starts to work but then of course "probe open" error.
    I feel like I'm missing something super simple here Like I have the wrong macro list or I'm missing something on my machine (programs from haas) or a setting or something. or #1 I'ma idiot. I have had very little help and I'm totally learning as I go. So if anyone wants to help me out that would be great I'll donate for your time
    May 2013
    Re: 1998 Haas vf3 Renishaw Probe and TS setup help.
    can someone give me an example of how to change/edit this please.
Name:	PROBE PIC .jpg
    O09799 (RENISHAW SETTING)
    (40120888.00 HAAS)
    (BASED ON 40120634.0C)
    G103 P1
    G187P2(MEDUIM SETTING)
    M98 P9725 (MACHINE CHECK)
    M98 P9854
    #156= 1 (2=RADOFF,1=DIAOFF)
    IF [ #6040 EQ 1 ] GOTO90 (RAD DIA)
    #156= 2
    N90
    #30= 582 (EDIT BASE NO.)
    (#[#30+11]=0) (1-INCH 0-MET STORE FLAG)
    G90 G80 G40 G00
    (CURRENT METRIC)
    #29= 1
    #31= 1 (METRIC STORE)
    IF [ #[ #30 + 11 ] NE 1 ] GOTO100
    #31= 1 / 25.4 (INCH STORE)
    N100
    IF [ #4006 EQ 21 ] GOTO101
    (CURRENT INCH)
    #29= 0.04
    #31= 25.4 (METRIC STORE)
    IF [ #[ #30 + 11 ] NE 1 ] GOTO101
    #31= 1 (INCH STORE)
    N101
    IF [ #[ #30 + 12 ] LE 0 ] GOTO102
    IF [ #[ #30 + 12 ] GT 1 ] GOTO102
    GOTO103
    N102
    #[ #30 + 12 ]= 0.3
    N103
    IF [ #174 NE 1 ] GOTO104
    #[ #30 + 0 ]= #163 * #31
    #[ #30 + 1 ]= #169 * #31
    #[ #30 + 3 ]= #5021 * #31
    #[ #30 + 4 ]= #5022 * #31
    GOTO106
    N104
    IF [ #174 NE 2 ] GOTO105
    #[ #30 + 2 ]= #166 * #31
    #[ #30 + 3 ]= #167 * #31
    #[ #30 + 4 ]= #168 * #31
    GOTO106
    N105
    #163= #[ #30 + 0 ] / #31 (Z POS. STATIC)
    #169= #[ #30 + 1 ] / #31 (Z POS. ROTATING)
    #166= #[ #30 + 2 ] / #31 (STYLUS SIZE)
    #167= #[ #30 + 3 ] / #31 (X POS.)
    #168= #[ #30 + 4 ] / #31 (Y POS.)
    #171= #[ #30 + 5 ] / #31 (Z APPROACH)
    #172= #[ #30 + 6 ] / #31 (Z CLEARANCE)
    #173= #[ #30 + 7 ] / #31 (TOOLS ABOVE THIS ROTATE)
    #177= #[ #30 + 8 ] / #31 (MAX. CUTTER DIA.)
    #164= #[ #30 + 9 ] (OFFSET TYPE)
    #176= #[ #30 + 10 ] (PROBE DIREC.)
    N106
    IF [ #4111 EQ 0 ] GOTO107
    IF [ #4111 EQ #0 ] GOTO107
    GOTO108
    N107
    #199= 0
    GOTO110
    N108
    #199= #5083
    N110
    M99
