588,501 active members*
5,227 visitors online*
Results 1 to 11 of 11
    Dec 2008
    16
    GCode missing
    Dear support!
    I have update my rPI to latest Raspbian version (February 2020, 2020-02-13). After installing PlanetCNCRPi_2020-03-24 everything looked fine. So I have imported my settings from previous OS (planet cnc versions are the same). Now the GCode content is gone. After application restart, there is no more "Active*".
    Mar 2017
    1342
    Re: GCode missing
    Check colors. Perhaps text color is transparent or same as background.
    Dec 2008
    16
    Re: GCode missing
    Quote Originally Posted by PlanetCNC View Post
    I don't think so. After application installation it looked like this . When I have imported my old settings, everything was fine, until I didn't restart the application. After restart it looks like on the pictures from previous post.
    One remark, same HW, same application only newer OS. It was working as well before "upgrade".
    May 2008
    266
    Re: GCode missing
    Video driver problem?
    You could try updating your driver.
    Dec 2008
    16
    Re: GCode missing
    Quote Originally Posted by blowlamp View Post
    Really? It's only RPI, so no special video drivers are used there.
    As I said, it was working, until I didn't change the PlanetCNC settings.
    May 2008
    266
    Re: GCode missing
    Just going by what I've seen with other computers.
    Mar 2017
    1342
    Re: GCode missing
    Settings from old TNG are not compatible. Please check this page:
    Dec 2008
    16
    Re: GCode missing
    Ok, so I have identified the problem. There is no issue with colors, but something different.
    I have reset all settings and went step-by-step with enabling new one. When I have disabled IO tab near to the GCode. When is disabled, GCode content is gone and otherwise is back. So I think, there is dependency bug with showing/hiding tabs.
    May 2008
    266
    Re: GCode missing
    Quote Originally Posted by Deklos View Post
    I can recreate this on my Windows 10 setup.
    Do this: 1/ Hide IO and save setting - Active G-Codes are displayed correctly.
    2/ Close PlanetCNC.
    3/ Open PlanetCNC and Active G-Codes have disappeared.
    Jan 2018
    1516
    Re: GCode missing
    That's computer 'updates' for you.
    Mar 2017
    1342
    Re: GCode missing
    I will fix this in next version.
  1. axis enable missing / DB35 DBX2.1 is missing
    By Max2000 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 06-13-2019, 06:54 AM
  2. Madcam for rhino .. Gcode missing
    By Apiiback in forum MadCAM
    Last Post: 03-22-2019, 10:02 PM
  3. Missing tool change in Gcode (SprutCAM)
    By bevinp in forum Tormach Personal CNC Mill
    Last Post: 07-09-2009, 02:26 AM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
