587,306 active members*
3,734 visitors online*
Page 1 of 3 123
Results 1 to 20 of 46
    Nov 2015
    260
    Independent PWM signal output
    Hi.
    With the TNGv2 controller I would like to run a small NEMA 17 Steper motor in addition to the normal tasks, and control the speed.
    Is it possible to use one of the three PWM outputs?
    One is already used for the spindle speed control.
    Is that possible? If so, how do I get the controls in the GUI of the controller.
    One should be used to control the pump. This pump foster the minimum quantities of lubrication / cooling
    Jan 2007
    626
    Re: Independent PWM signal output
    No experience with a TNGv2 controller, but you can't use a PWM signal to control Stepper motor speed, as far as I know.
    You will need to use a stepper motor driver as well as some sort of device to generate the correct signals for the driver.
    Devices such as this can be bought on Ebay cheaply.
    Nov 2015
    260
    Quote Originally Posted by Sterob View Post
    That's how I do it right now
    According to the manual, the output connection of the MK3 / 9 controller can generate 3 PWM signals.
    I'm just wondering how to configure the TNGV2 software.
    Jun 2017
    143
    Steppers need direction and step signals. pwm can't do that. You would need to use a spare axis on the controller to do that if you had one.
    Nov 2015
    260
    Of course you can operate a stepper using PWM pulse width modulation. It works very well here.
    For this I have a motor driver and a PWM controller. I do not want to control this with a potentiometer. but directly via the control.
    here is an example of a normal application.
    https://www.instructables.com/id/Control-a-Stepper-Motor-With-PWM/
    Jan 2007
    626
    I stand corrected.
    Sent from my SM-G920I using Tapatalk
    Nov 2015
    260
    Ok, then another question. The output connector can generate 3 PWM signals (this is in the technical specifications of the MK3 / 9 board)
    One is e.g. for the spindle speed, and has a corresponding control panel in the user interface.
    Now the question, can you get a control panel for the other two PWM signals in the graphical user interface?
    Apr 2013
    110
    If it can be useful, the further two PWM outputs are commands with the Gcode M63 P <pin>. there are examples in the Samples folder, I took the corresponding signal from the flat cable to control a blue laser.
    Mar 2017
    1328
    It is also possible to use stepper/servo motor as spindle. Controller can use PWM with fixed duty cycle and variable frequency (section Spindle/Frequency in settings).
    Nov 2015
    260
    The thing is, I want to control the speed of an additional motor (for a pump). Regardless of the g-code executed. Unfortunately, a slider is missing in the GUI.
    Mar 2017
    1328
    I'm working on "slider" button and on "menu" button.
    Nov 2015
    260
    Thank you. That pleases me.
    Mar 2017
    1328
    Latest beta version has new button options. Slider is not yet ready but "menu" can also be used.
    Here is download link:
    https://planet-cnc.com/wp-content/up...2020-05-18.zip
    For example unpack attached zip into your profile folder.
    Attached Files Attached Files
    Nov 2015
    260
    Sorry, I'm using OS X for experiments. Can I install the beta without any problems or will all the settings be lost on the Windows PC?
    Edit:I have now installed it on the work control computer. It has not burned down: D
    What can I say, there are a lot of buttons. So you can derive some of it and modify it for your own, I think.
    I still have a question, which menu? "Slider is not yet ready but "menu" can also be used."
    Jun 2017
    143
    Have a look in the default.zip file in the post just above your last post. It has a BtnBottom.txt that has examples of what can be done. Look for lines that contain typ=menu
    Nov 2015
    260
    I think this is the right line of code
    Code:
    cmd: "Machine.Output_On" image="BtnBottom/output.svg" imagechange="true" stroke=1.1 name="ON" size=60 typ=menu val="0@Output 1|1@Output 2|2@Output 3"
    But how can I get the output to send a PWM signal. As I said, I don't know the syntax.
    Jun 2017
    143
    I suspect this version is what you might need.
    Code:
    cmd: "File.Open_File" image="BtnBottom/features-list.svg" imagechange="true" stroke=1.1 size=50 typ=menu val="str:BtnBottom/Mickey.nc@Mickey|str:BtnBottom/Butterfly.nc@Butterfly|str:BtnBottom/Arcs.nc@Arcs|str:BtnBottom/Square.nc@Square"
    I think that will allow you to do something like put in menu options of 10%, 20% etc and then run a gcode script.
    As Andrej mentioned the slider stuff isn't complete yet, so you are probably stuck doing it like this for now.
    Nov 2015
    260
    Everything still has time. So far I have been operating the pump manually. I am very pleased that Planet-CNC is trying to implement my wish.
    Mar 2017
    1328
    Here is PWM example with cmd instead of g-code script:
    Code:
    cmd: "Machine.Output_PWM" image="BtnBottom/laser-beam.svg" imagechange="true" stroke=1.1 typ=menu val="[0;0]@PWM1 0%|[0;25]@PWM1 25%|[0;75]@PWM1 75%|[0;100]@PWM1 100%"
    I believe that this new "menu" button has lots of uses.
    Nov 2015
    260
    Hier ist ein PWM-Beispiel mit cmd anstelle von g-code script:
    Code:
    How can I declare less than 1%?
Page 1 of 3 123
  1. Output a signal on a pin
    By wentbackward in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-04-2014, 08:24 AM
  2. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  3. Input/output signal on 0M-C
    By padobranac in forum Fanuc
    Last Post: 10-28-2008, 03:49 PM
  4. No Output Signal
    By tz1238 in forum Machines running Mach Software
    Last Post: 01-27-2008, 09:57 PM
